[QGIS-Developer] Question
Marco Hugentobler marco.hugentobler at sourcepole.ch
Thu Oct 22 00:25:30 PDT 2020
Am 22.10.20 um 08:48 schrieb Raymond Nijssen:
> Hi Guillaume,
> A 5% progress after 5 days still sounds extremely slow! That would
> take approximately 100 days to finish on 1 core, or 2 days (72 hours!)
> on 32 cores.
> I don't know how large or complicated these shapefiles are, but you
> might try to find the solution in another way.
> - Make sure you are using indexes?
> - Select non-overlapping shapes and delete them?
> - Split the files in parts?
> - Move to Postgis? (Am I allowed to suggest that here? ;) )
> @Marco Shouldn't that code end up in QGIS or is it still in your repo
> for a reason?
I don't know the reason it was never merged. All the feedback has been
addressed and the unit tests passed.
Regards,
Marco
> Kind regards,
> Raymond
> On 22-10-2020 07:20, Marco Hugentobler wrote:
>> Hi Guillaume
>>  >My question: Is there a way to take advantage of the fact that I
>> have 32 cores on my computer with QGIS to make this calculation? I
>> don't understand why it is so slow.
>> Yes, there is. Compile the code from the
>> 'processing_multithreaded_vector' branch in my repo
>> (https://github.com/mhugent/QGIS/tree/processing_multithreaded_vector).
>> It calculates the difference operation on multiple cores (see also
>> https://github.com/qgis/QGIS/pull/33365).
>> Regards,
>> Marco
>> Am 22.10.20 um 03:05 schrieb guillaume martel:
>>> Hi,
>>> I don't know if I'm writing at the wrong place...
>>> I have 2 shapefiles and I want to do a "difference operation"
>>> (https://docs.qgis.org/3.10/en/docs/user_manual/processing_algs/qgis/vectoroverlay.html).
>>> My issue is as follow: Even though I have a powerful computer, after
>>> 5 days the calculation is only at 5%.
>>> Thank you for your help.
>>> Guillaume
>>> QGIS-Developer mailing list
>>> QGIS-Developer at lists.osgeo.org
>>> List info:https://lists.osgeo.org/mailman/listinfo/qgis-developer
>>> Unsubscribe:https://lists.osgeo.org/mailman/listinfo/qgis-developer
>> Dr. Marco Hugentobler
>> Sourcepole -  Linux & Open Source Solutions
>> Weberstrasse 5, CH-8004 Zürich, Switzerland
>> marco.hugentobler at sourcepole.ch  http://www.sourcepole.ch
>> List info: https://lists.osgeo.org/mailman/listinfo/qgis-developer
>> Unsubscribe: https://lists.osgeo.org/mailman/listinfo/qgis-developer
More information about the QGIS-Developer mailing list
