[QGIS-Developer] WFS-T, postgis and triggers
Alessandro Pasotti apasotti at gmail.com
Thu Oct 29 07:07:19 PDT 2020
On Thu, Oct 29, 2020 at 2:59 PM Denis Rouzaud <denis.rouzaud at gmail.com> wrote:
> Hi all,
> I have a WFS-T layer with a Postgis DB behind it.
> On my table, I have an insert trigger (before insert) which sets a field.
> When I create a feature on this layer in QGIS, I don't get back the value of this field (I have to refresh the data, by re-opening QGIS for instance).
> Is this expected?
Yes. The features are locally cached in a SQLite layer and a newly
created feature will be stored locally and not retrieve from the
server.
> Is there anything we can fix?
Of course yes but it would require re-fetching the feature(s) after an
insert or an update, I think it will slow things down.
Besides that there is no perfect solution to server-side changes: if
some other user will trigger a data change on the DB we will of course
miss it anyway.
> Am I doing something wrong?
No.
Cheers
Alessandro Pasotti
QCooperative:  www.qcooperative.net
ItOpen:   www.itopen.it
More information about the QGIS-Developer mailing list
