[QGIS-Developer] WFS-T, postgis and triggers
Denis Rouzaud
denis.rouzaud at gmail.com
Thu Oct 29 07:10:57 PDT 2020
Le jeu. 29 oct. 2020 à 15:07, Alessandro Pasotti <apasotti at gmail.com> a
écrit :
> On Thu, Oct 29, 2020 at 2:59 PM Denis Rouzaud <denis.rouzaud at gmail.com>
> wrote:
> > Hi all,
> > I have a WFS-T layer with a Postgis DB behind it.
> > On my table, I have an insert trigger (before insert) which sets a field.
> > When I create a feature on this layer in QGIS, I don't get back the
> value of this field (I have to refresh the data, by re-opening QGIS for
> instance).
> > Is this expected?
> Yes. The features are locally cached in a SQLite layer and a newly
> created feature will be stored locally and not retrieve from the
> server.
> > Is there anything we can fix?
> Of course yes but it would require re-fetching the feature(s) after an
> insert or an update, I think it will slow things down.
This could be done asynchronously?
It sounds like a quite common scenario (or not if nobody complained...).
Thanks for the answer anyway.
> Besides that there is no perfect solution to server-side changes: if
> some other user will trigger a data change on the DB we will of course
> miss it anyway.
> > Am I doing something wrong?
> No.
> Cheers
> Alessandro Pasotti
> QCooperative: www.qcooperative.net
> ItOpen: www.itopen.it
URL: <http://lists.osgeo.org/pipermail/qgis-developer/attachments/20201029/e59c215b/attachment.html>
