[QGIS-Developer] QGIS Debug build fails to launch in QtCreator
Tim Sutton tim at kartoza.com
Thu Sep 3 16:43:03 PDT 2020
Sorry my second message on this thread was probably a red herring - if I
run as sudo QGIS starts fine....
Regards
Tim
On Thu, Sep 3, 2020 at 11:48 PM Tim Sutton <tim at kartoza.com> wrote:
> Hi
> By the way poking around with it a bit more it seems to be crashing on
> this line @Nyal:
> 39fbc2ac331 src/core/qgsproject.cpp (Nyall Dawson               2020-08-31
> 10:30:20 +1000)   mMainAnnotationLayer->setTransformContext( context );
> Regards
> Tim
> On Thu, Sep 3, 2020 at 10:02 PM Tim Sutton <tim at kartoza.com> wrote:
>> Dear QGIS Developers
>> I am trying to run QGIS in debug mode in Qt-Creator. When I launch the
>> QGIS executable from QtCreator, I can see the application starting up but
>> then after a short time it crashes out. This happens both when I press the
>> green 'Run' triangle icon and when I press the green 'Start Debugging of
>> Target Project' triangle icon.
>> I am building on pop_os! (essentially Ubuntu 20.04, 64 bit) using GCC
>> without CCache and I have CMAKE_BUILD_TYPE set to Debug.
>> After starting QGIS it thinks for a while and then dies with the
>> following (full log of messages here [1]).
>> 21:21:14: Debugging starts
>> src/app/main.cpp:505 : (main) [0ms] Starting qgis main
>> src/core/qgsmessagelog.cpp:29 : (logMessage) [379ms] 2020-09-03T21:21:45
>> [1] Successfully loaded globalsettingsfile path:
>> /home/timlinux/dev/cpp/QGIS-Debug-Build/output/data/resources/qgis_global_settings.ini
>> src/core/qgscolorramp.cpp:732 : (loadFile) [103ms] filename=
>> /home/timlinux/dev/cpp/QGIS-Debug-Build/output/data/resources/cpt-city-qgis-min/grass/elevation.svg
>> loaded=0
>> QGIS died on signal 11Could not attach to process.  If your uid matches
>> the uid of the target
>> process, check the setting of /proc/sys/kernel/yama/ptrace_scope, or try
>> again as the root user.  For more details, see
>> /etc/sysctl.d/10-ptrace.conf
>> warning: process 223467 is already traced by process 223447
>> ptrace: Operation not permitted.
>> No thread selected
>> No stack.
>> gdb returned 256
>> 21:30:39: Debugging has finished
>> When I googled the ptrace error message above I found this StackOverflow
>> post[2] which seems to address the same issue. However, even after trying
>> all the various hints listed there, I still have the crash whenever I try
>> to launch QGIS in debug mode, or outside of a debugger.
>> Has anyone else experienced this? Can you help me fix it?
>> Many thanks!
>> Regards
>> Tim
>> [1] https://gist.github.com/timlinux/ac7468675e08f18428e3fe60d7e9633c
>> [2]
>> https://stackoverflow.com/questions/22120711/qt-creator-ptrace-operation-not-permitted-what-is-the-permanent-solution/30486572
>> Tim Sutton
>> Visit http://kartoza.com to find out about open source:
>>  * Desktop GIS programming services
>>  * Geospatial web development
>> * GIS Training
>> * Consulting Services
>> Skype: timlinux Irc: timlinux on #qgis at freenode.net
>> Tim is a member of the QGIS Project Steering Committee
>> Kartoza is a merger between Linfiniti and Afrispatial
> Tim Sutton
> * GIS Training
Tim Sutton
* GIS Training
URL: <http://lists.osgeo.org/pipermail/qgis-developer/attachments/20200904/d8e5e6fd/attachment.html>
More information about the QGIS-Developer mailing list
