[QGIS-Developer] QGIS Debug build fails to launch in QtCreator
Tim Sutton tim at kartoza.com
Thu Sep 3 15:48:25 PDT 2020
Hi
By the way poking around with it a bit more it seems to be crashing on this
line @Nyal:
39fbc2ac331 src/core/qgsproject.cpp (Nyall Dawson               2020-08-31
10:30:20 +1000)   mMainAnnotationLayer->setTransformContext( context );
Regards
Tim
On Thu, Sep 3, 2020 at 10:02 PM Tim Sutton <tim at kartoza.com> wrote:
> Dear QGIS Developers
> I am trying to run QGIS in debug mode in Qt-Creator. When I launch the
> QGIS executable from QtCreator, I can see the application starting up but
> then after a short time it crashes out. This happens both when I press the
> green 'Run' triangle icon and when I press the green 'Start Debugging of
> Target Project' triangle icon.
> I am building on pop_os! (essentially Ubuntu 20.04, 64 bit) using GCC
> without CCache and I have CMAKE_BUILD_TYPE set to Debug.
> After starting QGIS it thinks for a while and then dies with the following
> (full log of messages here [1]).
> 21:21:14: Debugging starts
> src/app/main.cpp:505 : (main) [0ms] Starting qgis main
> src/core/qgsmessagelog.cpp:29 : (logMessage) [379ms] 2020-09-03T21:21:45
> [1] Successfully loaded globalsettingsfile path:
> /home/timlinux/dev/cpp/QGIS-Debug-Build/output/data/resources/qgis_global_settings.ini
> src/core/qgscolorramp.cpp:732 : (loadFile) [103ms] filename=
> /home/timlinux/dev/cpp/QGIS-Debug-Build/output/data/resources/cpt-city-qgis-min/grass/elevation.svg
> loaded=0
> QGIS died on signal 11Could not attach to process.  If your uid matches
> the uid of the target
> process, check the setting of /proc/sys/kernel/yama/ptrace_scope, or try
> again as the root user.  For more details, see /etc/sysctl.d/10-ptrace.conf
> warning: process 223467 is already traced by process 223447
> ptrace: Operation not permitted.
> No thread selected
> No stack.
> gdb returned 256
> 21:30:39: Debugging has finished
> When I googled the ptrace error message above I found this StackOverflow
> post[2] which seems to address the same issue. However, even after trying
> all the various hints listed there, I still have the crash whenever I try
> to launch QGIS in debug mode, or outside of a debugger.
> Has anyone else experienced this? Can you help me fix it?
> Many thanks!
> Regards
> Tim
> [1] https://gist.github.com/timlinux/ac7468675e08f18428e3fe60d7e9633c
> [2]
> https://stackoverflow.com/questions/22120711/qt-creator-ptrace-operation-not-permitted-what-is-the-permanent-solution/30486572
> Tim Sutton
> Visit http://kartoza.com to find out about open source:
>  * Desktop GIS programming services
>  * Geospatial web development
> * GIS Training
> * Consulting Services
> Skype: timlinux Irc: timlinux on #qgis at freenode.net
> Tim is a member of the QGIS Project Steering Committee
> Kartoza is a merger between Linfiniti and Afrispatial
Tim Sutton
* GIS Training
URL: <http://lists.osgeo.org/pipermail/qgis-developer/attachments/20200903/f03a067e/attachment.html>
More information about the QGIS-Developer mailing list
