[QGIS-Developer] Library for importing dwg
Jesús de Diego Alarcón
jesdial at gmail.com
Fri Sep 4 05:38:20 PDT 2020
Dear all
I would like to know which library is using QGIS for importing dwg files
(this functionality is accessible in *File > Import/Export > Importing a
DXF or DWG file *).
I had supposed that this functionality was using the newly-developed OGR
CAD driver... But I have tried with ogr2ogr both command line and Python
console and dwg files are not supported (at least the same dwf file I am
able to import with the mentioned functionality).
Any help will be appreciated. Thank you in advance
Jesús de Diego
"La vida es linda, lo malo es que muchos confunden lindo con fácil."
Mafalda
URL: <http://lists.osgeo.org/pipermail/qgis-developer/attachments/20200904/3dc2127a/attachment.html>
