[QGIS-Developer] Library for importing dwg
Andreas Neumann a.neumann at carto.net
Fri Sep 4 05:48:18 PDT 2020
It is using the libdxfrw library.
Jürgen might have forked/patched it though, because activity in the
original project is basically stalled -  I think you can find our
version here: https://github.com/qgis/QGIS/tree/master/external/libdxfrw
Greetings,
Andreas
On 2020-09-04 14:38, Jesús de Diego Alarcón wrote:
> Dear all
> I would like to know which library is using QGIS for importing dwg files (this functionality is accessible in _File >  Import/Export > Importing a DXF or DWG file _).
> I had supposed that this functionality was using the newly-developed OGR CAD driver... But I have tried with ogr2ogr both command line and Python console and dwg files are not supported (at least the same dwf file I am able to import with the mentioned functionality).
> Any help will be appreciated. Thank you in advance
> Jesús de Diego
> jesdial at gmail.com
> "La vida es linda, lo malo es que muchos confunden lindo con fácil."
> Mafalda
> QGIS-Developer mailing list
> QGIS-Developer at lists.osgeo.org
> List info: https://lists.osgeo.org/mailman/listinfo/qgis-developer
> Unsubscribe: https://lists.osgeo.org/mailman/listinfo/qgis-developer
URL: <http://lists.osgeo.org/pipermail/qgis-developer/attachments/20200904/3abbc02f/attachment.html>
More information about the QGIS-Developer mailing list
