[QGIS-Developer] Library for importing dwg
Jesús de Diego Alarcón
jesdial at gmail.com
Fri Sep 4 08:43:10 PDT 2020
Hi Andreas
First of all, thank you so much for your (quick) answer. I will take a look
but it seems that libdxfrw is working for *dxf files, not dwg*...Any case I
will take a look.
Thanks again
Jesús de Diego
El vie., 4 sept. 2020 a las 14:48, Andreas Neumann (<a.neumann at carto.net>)
escribió:
> Hi,
> It is using the libdxfrw library.
> Jürgen might have forked/patched it though, because activity in the
> original project is basically stalled - I think you can find our version
> here: https://github.com/qgis/QGIS/tree/master/external/libdxfrw
> Greetings,
> Andreas
> On 2020-09-04 14:38, Jesús de Diego Alarcón wrote:
> Dear all
> I would like to know which library is using QGIS for importing dwg files
> (this functionality is accessible in *File > Import/Export > Importing a
> DXF or DWG file *).
> I had supposed that this functionality was using the newly-developed OGR
> CAD driver... But I have tried with ogr2ogr both command line and Python
> console and dwg files are not supported (at least the same dwf file I am
> able to import with the mentioned functionality).
> Any help will be appreciated. Thank you in advance
> Jesús de Diego
> "La vida es linda, lo malo es que muchos confunden lindo con fácil."
> Mafalda
> QGIS-Developer mailing list
> QGIS-Developer at lists.osgeo.org
> List info: https://lists.osgeo.org/mailman/listinfo/qgis-developer
> Unsubscribe: https://lists.osgeo.org/mailman/listinfo/qgis-developer
Mafalda
URL: <http://lists.osgeo.org/pipermail/qgis-developer/attachments/20200904/a16834d2/attachment.html>
