[QGIS-Developer] Library for importing dwg
Andreas Neumann
a.neumann at carto.net
Fri Sep 4 11:10:11 PDT 2020
Hi Jesús,
No - that's a misconception. Despite the name of the library it also
reads DWG files. It's not perfect, but it reads DWG ;-)
Greetings,
Andreas
Am 04.09.20 um 17:43 schrieb Jesús de Diego Alarcón:
> Hi Andreas
> First of all, thank you so much for your (quick) answer. I will take a
> look but it seems that libdxfrw is working for *dxf files, not
> dwg*...Any case I will take a look.
> Thanks again
> Jesús de Diego
> El vie., 4 sept. 2020 a las 14:48, Andreas Neumann
> (<a.neumann at carto.net <mailto:a.neumann at carto.net>>) escribió:
> Hi,
> It is using the libdxfrw library.
> Jürgen might have forked/patched it though, because activity in
> the original project is basically stalled - I think you can find
> our version here:
> https://github.com/qgis/QGIS/tree/master/external/libdxfrw
> Greetings,
> Andreas
> On 2020-09-04 14:38, Jesús de Diego Alarcón wrote:
>> Dear all
>> I would like to know which library is using QGIS for importing
>> dwg files (this functionality is accessible in /File >
>> Import/Export > Importing a DXF or DWG file /).
>> I had supposed that this functionality was using the
>> newly-developed OGR CAD driver... But I have tried with ogr2ogr
>> both command line and Python console and dwg files are not
>> supported (at least the same dwf file I am able to import with
>> the mentioned functionality).
>> Any help will be appreciated. Thank you in advance
>> Jesús de Diego
>> jesdial at gmail.com <mailto:jesdial at gmail.com>
>> "La vida es linda, lo malo es que muchos confunden lindo con fácil."
>> Mafalda
>> QGIS-Developer mailing list
>> QGIS-Developer at lists.osgeo.org
>> <mailto:QGIS-Developer at lists.osgeo.org>
>> List info: https://lists.osgeo.org/mailman/listinfo/qgis-developer
>> Unsubscribe: https://lists.osgeo.org/mailman/listinfo/qgis-developer
> Mafalda
URL: <http://lists.osgeo.org/pipermail/qgis-developer/attachments/20200904/140e1550/attachment.html>
