[QGIS-Developer] Library for importing dwg
Jesús de Diego Alarcón
jesdial at gmail.com
Fri Sep 4 13:10:42 PDT 2020
OK Let's try then
Thanks a lot
Jesús de Diego
El vie., 4 sept. 2020 a las 20:10, Andreas Neumann (<a.neumann at carto.net>)
escribió:
> Hi Jesús,
> No - that's a misconception. Despite the name of the library it also reads
> DWG files. It's not perfect, but it reads DWG ;-)
> Greetings,
> Andreas
> Am 04.09.20 um 17:43 schrieb Jesús de Diego Alarcón:
> Hi Andreas
> First of all, thank you so much for your (quick) answer. I will take a
> look but it seems that libdxfrw is working for *dxf files, not dwg*...Any
> case I will take a look.
> Thanks again
> Jesús de Diego
> El vie., 4 sept. 2020 a las 14:48, Andreas Neumann (<a.neumann at carto.net>)
> escribió:
>> Hi,
>> It is using the libdxfrw library.
>> Jürgen might have forked/patched it though, because activity in the
>> original project is basically stalled - I think you can find our version
>> here: https://github.com/qgis/QGIS/tree/master/external/libdxfrw
>> Greetings,
>> Andreas
>> On 2020-09-04 14:38, Jesús de Diego Alarcón wrote:
>> Dear all
>> I would like to know which library is using QGIS for importing dwg files
>> (this functionality is accessible in *File > Import/Export > Importing
>> a DXF or DWG file *).
>> I had supposed that this functionality was using the newly-developed OGR
>> CAD driver... But I have tried with ogr2ogr both command line and Python
>> console and dwg files are not supported (at least the same dwf file I am
>> able to import with the mentioned functionality).
>> Any help will be appreciated. Thank you in advance
>> Jesús de Diego
>> "La vida es linda, lo malo es que muchos confunden lindo con fácil."
>> Mafalda
>> QGIS-Developer mailing list
>> QGIS-Developer at lists.osgeo.org
>> List info: https://lists.osgeo.org/mailman/listinfo/qgis-developer
>> Unsubscribe: https://lists.osgeo.org/mailman/listinfo/qgis-developer
> Mafalda
Mafalda
URL: <http://lists.osgeo.org/pipermail/qgis-developer/attachments/20200904/506ec75a/attachment.html>
