[QGIS-Developer] Library for importing dwg
Nyall Dawson
nyall.dawson at gmail.com
Sun Sep 6 16:22:15 PDT 2020
On Sat, 5 Sep 2020 at 06:11, Jesús de Diego Alarcón <jesdial at gmail.com> wrote:
> OK Let's try then
FYI there's also libredwg -- https://github.com/LibreDWG/libredwg ,
which is seeing a lot of development focus recently (maybe at some
stage we should abstract out the backend dwg library in qgis to give
users a choice of backend to use for conversion...)
Nyall
> Thanks a lot
> Jesús de Diego
> El vie., 4 sept. 2020 a las 20:10, Andreas Neumann (<a.neumann at carto.net>) escribió:
>> Hi Jesús,
>> No - that's a misconception. Despite the name of the library it also reads DWG files. It's not perfect, but it reads DWG ;-)
>> Greetings,
>> Andreas
>> Am 04.09.20 um 17:43 schrieb Jesús de Diego Alarcón:
>> Hi Andreas
>> First of all, thank you so much for your (quick) answer. I will take a look but it seems that libdxfrw is working for dxf files, not dwg...Any case I will take a look.
>> Thanks again
>> Jesús de Diego
>> El vie., 4 sept. 2020 a las 14:48, Andreas Neumann (<a.neumann at carto.net>) escribió:
>>> Hi,
>>> It is using the libdxfrw library.
>>> Jürgen might have forked/patched it though, because activity in the original project is basically stalled - I think you can find our version here: https://github.com/qgis/QGIS/tree/master/external/libdxfrw
>>> Greetings,
>>> Andreas
>>> On 2020-09-04 14:38, Jesús de Diego Alarcón wrote:
>>> Dear all
>>> I would like to know which library is using QGIS for importing dwg files (this functionality is accessible in File > Import/Export > Importing a DXF or DWG file ).
>>> I had supposed that this functionality was using the newly-developed OGR CAD driver... But I have tried with ogr2ogr both command line and Python console and dwg files are not supported (at least the same dwf file I am able to import with the mentioned functionality).
>>> Any help will be appreciated. Thank you in advance
>>> Jesús de Diego
>>> "La vida es linda, lo malo es que muchos confunden lindo con fácil."
>>> Mafalda
>>> QGIS-Developer mailing list
>>> QGIS-Developer at lists.osgeo.org
>>> List info: https://lists.osgeo.org/mailman/listinfo/qgis-developer
>>> Unsubscribe: https://lists.osgeo.org/mailman/listinfo/qgis-developer
>> Mafalda
> Mafalda
