[QGIS-Developer] Library for importing dwg
Jesús de Diego Alarcón
jesdial at gmail.com
Mon Sep 7 04:28:19 PDT 2020
OK Nyall
I will also take a look
Thanks
Jesús
El lun., 7 sept. 2020 a las 1:22, Nyall Dawson (<nyall.dawson at gmail.com>)
escribió:
> On Sat, 5 Sep 2020 at 06:11, Jesús de Diego Alarcón <jesdial at gmail.com>
> wrote:
> > OK Let's try then
> FYI there's also libredwg -- https://github.com/LibreDWG/libredwg ,
> which is seeing a lot of development focus recently (maybe at some
> stage we should abstract out the backend dwg library in qgis to give
> users a choice of backend to use for conversion...)
> Nyall
> > Thanks a lot
> > Jesús de Diego
> > El vie., 4 sept. 2020 a las 20:10, Andreas Neumann (<a.neumann at carto.net>)
> escribió:
> >> Hi Jesús,
> >> No - that's a misconception. Despite the name of the library it also
> reads DWG files. It's not perfect, but it reads DWG ;-)
> >> Greetings,
> >> Andreas
> >> Am 04.09.20 um 17:43 schrieb Jesús de Diego Alarcón:
> >> Hi Andreas
> >> First of all, thank you so much for your (quick) answer. I will take a
> look but it seems that libdxfrw is working for dxf files, not dwg...Any
> case I will take a look.
> >> Thanks again
> >> Jesús de Diego
> >> El vie., 4 sept. 2020 a las 14:48, Andreas Neumann (<
> a.neumann at carto.net>) escribió:
> >>> Hi,
> >>> It is using the libdxfrw library.
> >>> Jürgen might have forked/patched it though, because activity in the
> original project is basically stalled - I think you can find our version
> here: https://github.com/qgis/QGIS/tree/master/external/libdxfrw
> >>> Greetings,
> >>> Andreas
> >>> On 2020-09-04 14:38, Jesús de Diego Alarcón wrote:
> >>> Dear all
> >>> I would like to know which library is using QGIS for importing dwg
> files (this functionality is accessible in File > Import/Export >
> Importing a DXF or DWG file ).
> >>> I had supposed that this functionality was using the newly-developed
> OGR CAD driver... But I have tried with ogr2ogr both command line and
> Python console and dwg files are not supported (at least the same dwf file
> I am able to import with the mentioned functionality).
> >>> Any help will be appreciated. Thank you in advance
> >>> Jesús de Diego
> >>> "La vida es linda, lo malo es que muchos confunden lindo con fácil."
> >>> Mafalda
> >>> _______________________________________________
> >>> QGIS-Developer mailing list
> >>> QGIS-Developer at lists.osgeo.org
> >>> List info: https://lists.osgeo.org/mailman/listinfo/qgis-developer
> >>> Unsubscribe: https://lists.osgeo.org/mailman/listinfo/qgis-developer
> >> Mafalda
> > Mafalda
Mafalda
URL: <http://lists.osgeo.org/pipermail/qgis-developer/attachments/20200907/adaf717e/attachment.html>
