[QGIS-Developer] Is a plugin for QGIS3 with the user interface defined by code acceptable for the repository?
Richard Duivenvoorde
rdmailings at duif.net
Mon Sep 7 05:56:02 PDT 2020
On 9/7/20 2:18 PM, Luis Eduardo wrote:
> Thank you very much for responding.
> Excuse me, for insisting, could you please clarify the answer to the first question.
> Would a plugin with the user interface defined only by code (no .ui file) be acceptable for the QGIS repository?
Yes, why should it not be?
A ui file is (via compiling with uic(?)) also converted to (python) code, so I do not see a reason why if you do this (laborious) work yourself, it would not be acceptable?
Or do (do you, or others, think) I miss something here?
Regards,
