[QGIS-Developer] Travis failing in QGIS-Documentation
DelazJ
delazj at gmail.com
Mon Sep 7 07:05:46 PDT 2020
Hi devs,
A gentle ping to help us fix doc travis reports (actually PyQGIS Cookbook
tests infrastructure in). Unless there's some ongoing efforts I'm not aware
of.
Thanks.
Harrissou
Le mar. 1 sept. 2020 à 13:11, DelazJ <delazj at gmail.com> a écrit :
> Hi,
> Like Matteo, I can't locally test the doctest build so travis/docker are
> the masters and last resort here.
> I gave a look to the travis reports and the code testing parts of the docs
> are the reasons for failure. But I'm not sure the recent broken master
> docker is the only reason. I tried to fix some obvious issues in our code
> samples pointed by the various and changing reports of travis but there are
> a bunch of feedback I do not understand (or don't know where to look for a
> fix) so would be grateful if someone can give it a look. A single small PR
> ending with the red cross from Travis is making me crazy. I have summarized
> some of the issues at
> https://github.com/qgis/QGIS-Documentation/labels/build%2Fdoctest%2Ftravis
> Thanks in advance,
> Harrissou
> Le ven. 28 août 2020 à 10:51, matteo <matteo.ghetta at gmail.com> a écrit :
>> Hi Richard,
>> > in is in the conf.py:
>> > https://github.com/qgis/QGIS-Documentation/blob/master/conf.py#L343
>> oh right.... my fault.. but tests are still failing with a compiled
>> version of QGIS. Can I ask you how you user.mk file looks like?
>> Cheers and thanks
>> Matteo
>> QGIS-Developer mailing list
>> QGIS-Developer at lists.osgeo.org
>> List info: https://lists.osgeo.org/mailman/listinfo/qgis-developer
>> Unsubscribe: https://lists.osgeo.org/mailman/listinfo/qgis-developer
URL: <http://lists.osgeo.org/pipermail/qgis-developer/attachments/20200907/3e57bd8b/attachment-0001.html>
