[QGIS-Developer] py3_env in Windows installers
Jürgen E. Fischer
jef at norbit.de
Tue Sep 8 05:33:55 PDT 2020
Hi Richard,
On Tue, 08. Sep 2020 at 10:45:21 +0200, Richard Duivenvoorde wrote:
> On 9/8/20 10:32 AM, Jürgen E. Fischer wrote:
> > > I know this was to be able to handle both py2 and py3, but I do not think
> > > we need to use python2 anymore is it?
> > py2 is still available in osgeo4w - although we don't use it anymore for QGIS.
> IS it still used by other osgeo4w components? Would be nice to clean it out
> if that was possible (as py2 not supported etc etc)?
None non-obsolete components at least. That probably also applies to the VC
2008 runtime.
> > > In that case I would propose to make py3_env part of the osgeo4w.bat file
> > > so we can instruct people to just go to the osgeo4w bat file to eventually
> > > pip install modules usable in QGIS?
> > You could also just move py3_env.bat to etc\ini\python3-core.bat and create an
> > empty py3_env.bat.
> That is for this user yes? Or are you talking about in the sources?
Which user? I'm talking about osgeo4w. There's a etc/ini/python-core.bat
in python-core (2) that makes python2 default if it's installed and that used
to be the default installed python. py3_env.bat was added to switch from there
to python3. If we were going to change that, the contents of py3_env.bat
should be moved to etc/ini - so that it's sourced by o4w_env.bat, which all the
batch files that start applications source. The osgeo4w shell itself doesn't
use any python.
All of the above is osgeo4w and not QGIS.
Jürgen
Jürgen E. Fischer norBIT GmbH Tel. +49-4931-918175-31
Dipl.-Inf. (FH) Rheinstraße 13 Fax. +49-4931-918175-50
Software Engineer D-26506 Norden https://www.norbit.de
QGIS release manager (PSC) Germany IRC: jef on FreeNode
Desc: not available
URL: <http://lists.osgeo.org/pipermail/qgis-developer/attachments/20200908/9550211c/attachment.sig>
