[QGIS-Developer] PG loading broken in master
Tim Sutton
tim at kartoza.com
Tue Sep 15 14:35:12 PDT 2020
Hi Andreas
If you are not already aware of it, check out git bisect, which helps you
to isolate a breaking commit quickly.
https://www.metaltoad.com/blog/beginners-guide-git-bisect-process-elimination
Regards
Tim
On Tue, 15 Sep 2020, 16:46 Andreas Neumann, <a.neumann at carto.net> wrote:
> Hi Jorge,
> There is only one authcfg. The service configuration doesn't contain auth
> information - just host, port and db. It is quite normal that you have a
> service name and an authcfg in the same data source.
> I am currently compiling older commits to find out which commit still
> worked.
> Probably I know more tomorrow.
> Greetings,
> Andreas
> On 2020-09-15 17:40, Jorge Gustavo Rocha wrote:
> Hi Andreas,
> Just a quick question: if both are present, should one be ignored? Which
> auth configuration should be used in that case?
> Regards,
> Jorge
> On 15/09/20 16:05, Andreas Neumann wrote:
> Ok -
> I am currently building older versions of master to find out which
> commit still worked.
> Will let you know, if I know more.
> Thanks,
> Andreas
> On 2020-09-15 17:02, Alessandro Pasotti wrote:
> On Tue, Sep 15, 2020 at 4:52 PM Andreas Neumann <a.neumann at carto.net
> <mailto:a.neumann at carto.net>> wrote:
> Hi,
> Some recent commit broke all my projects that load PG layers with a
> datasource like:
> <datasource>service='pub' authcfg=sogis00 key='t_id' srid=2056
> type=Point checkPrimaryKeyUnicity='1' table="schema"."table"
> (geometrie) sql=</datasource>
> Means a combination of PG service name and auth config. None of the
> PG layers in the project can be loaded.
> Any idea what recent commit might be the culprit?
> Sorry I don't, but I'm in bug fixing mode right now and working on
> other PG issues, if you have any chance to let me debug your project
> please let me know.
> Cheers
> QGIS-Developer mailing list
> QGIS-Developer at lists.osgeo.org
> List info: https://lists.osgeo.org/mailman/listinfo/qgis-developer
> Unsubscribe: https://lists.osgeo.org/mailman/listinfo/qgis-developer
> J. Gustavo
URL: <http://lists.osgeo.org/pipermail/qgis-developer/attachments/20200915/3d9c18c5/attachment.html>
