[QGIS-Developer] PG loading broken in master
Andreas Neumann
a.neumann at carto.net
Wed Sep 16 00:40:33 PDT 2020
Ok - I am trying to learn git bisect, but I'm really confused to how it
works:
Here is what I did:
$ git bisect start
$ git bisect good c6e28828dd3c9d0459033643ced4ba8994d7bc92
$ git bisect bad 1c2b4ae2b0f3add7767d473f2b4137d7de9afd24
Bisecting: 18 revisions left to test after this (roughly 4 steps)
[89e4d4925a7ff26561acde84a861986cb30af961] enable QgsMeshTriangulation
with SIP and change SIP_CONCAT_PARTS
Why on earth is git bisect checking out something older than the good
commit? Really strange ...
I would have expected that git bisect would check out something between
the good and the bad commit.
Confused ...
Andreas
On 2020-09-15 23:35, Tim Sutton wrote:
> Hi Andreas
> If you are not already aware of it, check out git bisect, which helps you to isolate a breaking commit quickly.
> https://www.metaltoad.com/blog/beginners-guide-git-bisect-process-elimination
> Regards
> Tim
> On Tue, 15 Sep 2020, 16:46 Andreas Neumann, <a.neumann at carto.net> wrote:
> Hi Jorge,
> There is only one authcfg. The service configuration doesn't contain auth information - just host, port and db. It is quite normal that you have a service name and an authcfg in the same data source.
> I am currently compiling older commits to find out which commit still worked.
> Probably I know more tomorrow.
> Greetings,
> Andreas
> On 2020-09-15 17:40, Jorge Gustavo Rocha wrote:
> Hi Andreas,
> Just a quick question: if both are present, should one be ignored? Which
> auth configuration should be used in that case?
> Regards,
> Jorge
> On 15/09/20 16:05, Andreas Neumann wrote: Ok -
> I am currently building older versions of master to find out which
> Will let you know, if I know more.
> Thanks,
> Andreas
> On 2020-09-15 17:02, Alessandro Pasotti wrote:
> On Tue, Sep 15, 2020 at 4:52 PM Andreas Neumann <a.neumann at carto.net
> <mailto:a.neumann at carto.net>> wrote:
> Hi,
> Some recent commit broke all my projects that load PG layers with a
> datasource like:
> <datasource>service='pub' authcfg=sogis00 key='t_id' srid=2056
> type=Point checkPrimaryKeyUnicity='1' table="schema"."table"
> (geometrie) sql=</datasource>
> Means a combination of PG service name and auth config. None of the
> PG layers in the project can be loaded.
> Any idea what recent commit might be the culprit?
> Sorry I don't, but I'm in bug fixing mode right now and working on
> other PG issues, if you have any chance to let me debug your project
> please let me know.
> Cheers
QGIS-Developer mailing list
QGIS-Developer at lists.osgeo.org
List info: https://lists.osgeo.org/mailman/listinfo/qgis-developer
Unsubscribe: https://lists.osgeo.org/mailman/listinfo/qgis-developer
J. Gustavo
URL: <http://lists.osgeo.org/pipermail/qgis-developer/attachments/20200916/ed33af8d/attachment.html>
