[QGIS-Developer] Python console starting up very slow in master?
Richard Duivenvoorde
rdmailings at duif.net
Fri Sep 18 00:18:12 PDT 2020
Hi Devs,
I have the impression that the startup of the Python console in current master is very slow.
In 3.10 and 3.14 if I click the little python button, the Python Console panel is there within a snap.
In Master it takes at least 5 seconds...
And again if you open the 'Editor' pane in it
Same/Clean profiles
Others see the same?
(I know myself I added a baseclass to the edit-panes [0],
but that should not make stuff start slower...?)
Regards,
[0] https://github.com/qgis/QGIS/pull/37602
QGIS version
3.15.0-Master
QGIS code revision
527a08ca5e
Compiled against Qt
5.14.2
Running against Qt
5.14.2
Compiled against GDAL/OGR
3.1.3
Running against GDAL/OGR
3.1.3
Compiled against GEOS
3.8.1-CAPI-1.13.3
Running against GEOS
3.8.1-CAPI-1.13.3
Compiled against SQLite
3.33.0
Running against SQLite
3.33.0
PostgreSQL Client Version
12.4 (Debian 12.4-1)
SpatiaLite Version
5.0.0
QWT Version
6.1.4
QScintilla2 Version
2.11.2
Compiled against PROJ
7.1.1
Running against PROJ
Rel. 7.1.1, September 1st, 2020
OS Version
Debian GNU/Linux bullseye/sid
This copy of QGIS writes debugging output.
Active python plugins
MetaSearch;
processing;
db_manager
