[QGIS-Developer] Python console starting up very slow in master?
Salvatore Larosa
lrssvtml at gmail.com
Sat Sep 19 03:53:15 PDT 2020
Hi Richard,
I can confirm, please file a ticket. I am on it right now!
Thanks,
-SL
On Fri, Sep 18, 2020 at 9:18 AM Richard Duivenvoorde <rdmailings at duif.net>
wrote:
> Hi Devs,
> I have the impression that the startup of the Python console in current
> master is very slow.
> In 3.10 and 3.14 if I click the little python button, the Python Console
> panel is there within a snap.
> In Master it takes at least 5 seconds...
> And again if you open the 'Editor' pane in it
> Same/Clean profiles
> Others see the same?
> (I know myself I added a baseclass to the edit-panes [0],
> but that should not make stuff start slower...?)
> Regards,
> [0] https://github.com/qgis/QGIS/pull/37602
> QGIS version
> 3.15.0-Master
> QGIS code revision
> 527a08ca5e
> Compiled against Qt
> 5.14.2
> Running against Qt
> 5.14.2
> Compiled against GDAL/OGR
> 3.1.3
> Running against GDAL/OGR
> 3.1.3
> Compiled against GEOS
> 3.8.1-CAPI-1.13.3
> Running against GEOS
> 3.8.1-CAPI-1.13.3
> Compiled against SQLite
> 3.33.0
> Running against SQLite
> 3.33.0
> PostgreSQL Client Version
> 12.4 (Debian 12.4-1)
> SpatiaLite Version
> 5.0.0
> QWT Version
> 6.1.4
> QScintilla2 Version
> 2.11.2
> Compiled against PROJ
> 7.1.1
> Running against PROJ
> Rel. 7.1.1, September 1st, 2020
> OS Version
> Debian GNU/Linux bullseye/sid
> This copy of QGIS writes debugging output.
> Active python plugins
> MetaSearch;
> processing;
> db_manager
> QGIS-Developer mailing list
> QGIS-Developer at lists.osgeo.org
> List info: https://lists.osgeo.org/mailman/listinfo/qgis-developer
> Unsubscribe: https://lists.osgeo.org/mailman/listinfo/qgis-developer
Salvatore Larosa
linkedIn: http://linkedin.com/in/larosasalvatore
twitter: @lrssvt
skype: s.larosa
IRC: lrssvt on freenode
URL: <http://lists.osgeo.org/pipermail/qgis-developer/attachments/20200919/b0c2930f/attachment-0001.html>
