[QGIS-Developer] Python console starting up very slow in master?
Salvatore Larosa
lrssvtml at gmail.com
Sat Sep 19 04:32:17 PDT 2020
Hi Richard,
I managed to catch the problem [0] quickly, no need to file a ticket.
Cheers,
-SL
[0] - https://github.com/qgis/QGIS/pull/38873
On Sat, Sep 19, 2020 at 12:53 PM Salvatore Larosa <lrssvtml at gmail.com>
wrote:
> Hi Richard,
> I can confirm, please file a ticket. I am on it right now!
> Thanks,
> -SL
> On Fri, Sep 18, 2020 at 9:18 AM Richard Duivenvoorde <rdmailings at duif.net>
> wrote:
>> Hi Devs,
>> I have the impression that the startup of the Python console in current
>> master is very slow.
>> In 3.10 and 3.14 if I click the little python button, the Python Console
>> panel is there within a snap.
>> In Master it takes at least 5 seconds...
>> And again if you open the 'Editor' pane in it
>> Same/Clean profiles
>> Others see the same?
>> (I know myself I added a baseclass to the edit-panes [0],
>> but that should not make stuff start slower...?)
>> Regards,
>> [0] https://github.com/qgis/QGIS/pull/37602
>> QGIS version
>> 3.15.0-Master
>> QGIS code revision
>> 527a08ca5e
>> Compiled against Qt
>> 5.14.2
>> Running against Qt
>> 5.14.2
>> Compiled against GDAL/OGR
>> 3.1.3
>> Running against GDAL/OGR
>> 3.1.3
>> Compiled against GEOS
>> 3.8.1-CAPI-1.13.3
>> Running against GEOS
>> 3.8.1-CAPI-1.13.3
>> Compiled against SQLite
>> 3.33.0
>> Running against SQLite
>> 3.33.0
>> PostgreSQL Client Version
>> 12.4 (Debian 12.4-1)
>> SpatiaLite Version
>> 5.0.0
>> QWT Version
>> 6.1.4
>> QScintilla2 Version
>> 2.11.2
>> Compiled against PROJ
>> 7.1.1
>> Running against PROJ
>> Rel. 7.1.1, September 1st, 2020
>> OS Version
>> Debian GNU/Linux bullseye/sid
>> This copy of QGIS writes debugging output.
>> Active python plugins
>> MetaSearch;
>> processing;
>> db_manager
>> QGIS-Developer mailing list
>> QGIS-Developer at lists.osgeo.org
>> List info: https://lists.osgeo.org/mailman/listinfo/qgis-developer
>> Unsubscribe: https://lists.osgeo.org/mailman/listinfo/qgis-developer
> Salvatore Larosa
> linkedIn: http://linkedin.com/in/larosasalvatore
> twitter: @lrssvt
> skype: s.larosa
> IRC: lrssvt on freenode
Salvatore Larosa
twitter: @lrssvt
skype: s.larosa
URL: <http://lists.osgeo.org/pipermail/qgis-developer/attachments/20200919/04842ee6/attachment.html>
