[QGIS-Developer] Publishing new plugin gives 'you cannot modify'
Etienne Trimaille
etienne.trimaille at gmail.com
Sat Sep 19 02:18:14 PDT 2020
I have checked this other plugin. The folder inside the zip is called
"LandSurfaceTemperature". So your folder in the zip can't be called with
this name.
Le sam. 19 sept. 2020 à 09:53, Chirag Dasannacharya <chirag8cd at gmail.com> a
écrit :
> Hi Etienne,
> It's named 'LandSurfaceTemperature', packaged in
> 'LandSurfaceTemperature.zip'.
> Last I checked, I don't think there was another plugin with the exact same
> name. There
> is a 'Land Surface Temperature' with the same purpose, but incompatible
> with
> QGIS 3+. Do you think this might be the issue?
> On Sat, 19 Sep 2020 at 12:13, Etienne Trimaille <
> etienne.trimaille at gmail.com> wrote:
>> What is the name of the plugin? Maybe there is already a plugin with the
>> same package/folder name? (So you don't own this plugin)
>> Le sam. 19 sept. 2020 à 07:54, Chirag Dasannacharya <chirag8cd at gmail.com>
>> a écrit :
>>> Hi all,
>>> I'm a new developer, I'm trying to publish a plugin for the first time.
>>> Apologies if this is trivial. On uploading the zip file and clicking the
>>> upload button, I get a message saying
>>> 'You cannot modifiy this plugin.' (sic)
>>> Am I missing something?
>>> QGIS-Developer mailing list
>>> QGIS-Developer at lists.osgeo.org
>>> List info: https://lists.osgeo.org/mailman/listinfo/qgis-developer
>>> Unsubscribe: https://lists.osgeo.org/mailman/listinfo/qgis-developer
URL: <http://lists.osgeo.org/pipermail/qgis-developer/attachments/20200919/a589036f/attachment.html>
