[QGIS-Developer] Publishing new plugin gives 'you cannot modify'
Chirag Dasannacharya
chirag8cd at gmail.com
Sat Sep 19 04:11:28 PDT 2020
Thank you very much for your input! Turns out that was the
problem, I was able to upload the plugin under a different
name, LandSurfaceTemperatureV3 (sounds a little weird),
and it works just fine. Again, thanks a lot!
On Sat, 19 Sep 2020 at 14:48, Etienne Trimaille <etienne.trimaille at gmail.com>
wrote:
> I have checked this other plugin. The folder inside the zip is called
> "LandSurfaceTemperature". So your folder in the zip can't be called with
> this name.
> Le sam. 19 sept. 2020 à 09:53, Chirag Dasannacharya <chirag8cd at gmail.com>
> a écrit :
>> Hi Etienne,
>> It's named 'LandSurfaceTemperature', packaged in
>> 'LandSurfaceTemperature.zip'.
>> Last I checked, I don't think there was another plugin with the exact
>> same name. There
>> is a 'Land Surface Temperature' with the same purpose, but incompatible
>> with
>> QGIS 3+. Do you think this might be the issue?
>> On Sat, 19 Sep 2020 at 12:13, Etienne Trimaille <
>> etienne.trimaille at gmail.com> wrote:
>>> What is the name of the plugin? Maybe there is already a plugin with the
>>> same package/folder name? (So you don't own this plugin)
>>> Le sam. 19 sept. 2020 à 07:54, Chirag Dasannacharya <chirag8cd at gmail.com>
>>> a écrit :
>>>> Hi all,
>>>> I'm a new developer, I'm trying to publish a plugin for the first time.
>>>> Apologies if this is trivial. On uploading the zip file and clicking the
>>>> upload button, I get a message saying
>>>> 'You cannot modifiy this plugin.' (sic)
>>>> Am I missing something?
>>>> _______________________________________________
>>>> QGIS-Developer mailing list
>>>> QGIS-Developer at lists.osgeo.org
>>>> List info: https://lists.osgeo.org/mailman/listinfo/qgis-developer
>>>> Unsubscribe: https://lists.osgeo.org/mailman/listinfo/qgis-developer
URL: <http://lists.osgeo.org/pipermail/qgis-developer/attachments/20200919/8c437143/attachment.html>
