[QGIS-Developer] numeric values in text edit widget (forms)
Thomas Schüttenberg
thomas at qgis.de
Thu Sep 24 02:39:15 PDT 2020
Hi!
I just realized that numeric values (from a PostGIS table) are not displayed by a text edit widget in an attribute form, everything that is instead shown is 0 [zero].
I switched from the default range widget to text edit widget, because I just want to show the attributes, read only, and this way it looks nicer to me. (BTW, the min/max values of the randfe widget are quite tremendous, see https://github.com/qgis/QGIS/issues/24725)
To me this seems to be a bug and I suspect it to be related to localization (de_DE) issues which are themselves numerous. Therefore I wanted to check if anybody here knows an already existing/open bug report on this, because I did not find something exactly fitting. - Otherwise I will file a new one.
I tested on Windows with QGIS 3.4.12, 3.10.9 and 3.14.1.
Cheers
Thomas
