[QGIS-Developer] numeric values in text edit widget (forms)
Alessandro Pasotti
apasotti at gmail.com
Thu Sep 24 03:08:27 PDT 2020
On Thu, Sep 24, 2020 at 12:01 PM Thomas Schüttenberg <thomas at qgis.de> wrote:
> Hi!
> I just realized that numeric values (from a PostGIS table) are not displayed by a text edit widget in an attribute form, everything that is instead shown is 0 [zero].
> I switched from the default range widget to text edit widget, because I just want to show the attributes, read only, and this way it looks nicer to me. (BTW, the min/max values of the randfe widget are quite tremendous, see https://github.com/qgis/QGIS/issues/24725)
> To me this seems to be a bug and I suspect it to be related to localization (de_DE) issues which are themselves numerous. Therefore I wanted to check if anybody here knows an already existing/open bug report on this, because I did not find something exactly fitting. - Otherwise I will file a new one.
Please file a new ticket, can you also check if with en_US locale the
issue is still there?
> I tested on Windows with QGIS 3.4.12, 3.10.9 and 3.14.1.
> Cheers
> Thomas
> QGIS-Developer mailing list
> QGIS-Developer at lists.osgeo.org
> List info: https://lists.osgeo.org/mailman/listinfo/qgis-developer
> Unsubscribe: https://lists.osgeo.org/mailman/listinfo/qgis-developer
Alessandro Pasotti
QCooperative: www.qcooperative.net
ItOpen: www.itopen.it
