[QGIS-Developer] numeric values in text edit widget (forms)
thomas thomas at qgis.de
Sat Sep 26 05:23:30 PDT 2020
Hi!
In order to be able to give a proper report I tested again with my tables from scratch and, guess
what, I was not able to reproduce the strange and inconsistent behavior of the form.
In the end it seems like it is caused (only) by my broken qml/layer style code.
During the long development history of my huge and complex form there was quite a lot of clicking
and copying style parts back and forth, between layers and possibly across versions of QGIS.... At
some time it broke without been noticed at first. - I found no way of repairing it, so will have to
rebuild the form. m(
Sorry for the noise, all the best
Thomas
Am 24.09.20 um 12:08 schrieb Alessandro Pasotti:
> On Thu, Sep 24, 2020 at 12:01 PM Thomas Schüttenberg <thomas at qgis.de> wrote:
>> Hi!
>> I just realized that numeric values (from a PostGIS table) are not displayed by a text edit widget in an attribute form, everything that is instead shown is 0 [zero].
>> I switched from the default range widget to text edit widget, because I just want to show the attributes, read only, and this way it looks nicer to me. (BTW, the min/max values of the randfe widget are quite tremendous, see https://github.com/qgis/QGIS/issues/24725)
>> To me this seems to be a bug and I suspect it to be related to localization (de_DE) issues which are themselves numerous. Therefore I wanted to check if anybody here knows an already existing/open bug report on this, because I did not find something exactly fitting. - Otherwise I will file a new one.
> Please file a new ticket, can you also check if with en_US locale the
> issue is still there?
>> I tested on Windows with QGIS 3.4.12, 3.10.9 and 3.14.1.
>> Cheers
>> Thomas
>> QGIS-Developer mailing list
>> QGIS-Developer at lists.osgeo.org
>> List info: https://lists.osgeo.org/mailman/listinfo/qgis-developer
>> Unsubscribe: https://lists.osgeo.org/mailman/listinfo/qgis-developer
More information about the QGIS-Developer mailing list
