[QGIS-Developer] numeric values in text edit widget (forms)
Alessandro Pasotti
apasotti at gmail.com
Sat Sep 26 06:33:32 PDT 2020
No worries, thanks for the update!
On Sat, Sep 26, 2020, 14:23 thomas <thomas at qgis.de> wrote:
> Hi!
> In order to be able to give a proper report I tested again with my tables
> from scratch and, guess
> what, I was not able to reproduce the strange and inconsistent behavior of
> the form.
> In the end it seems like it is caused (only) by my broken qml/layer style
> code.
> During the long development history of my huge and complex form there was
> quite a lot of clicking
> and copying style parts back and forth, between layers and possibly across
> versions of QGIS.... At
> some time it broke without been noticed at first. - I found no way of
> repairing it, so will have to
> rebuild the form. m(
> Sorry for the noise, all the best
> Thomas
> Am 24.09.20 um 12:08 schrieb Alessandro Pasotti:
> > On Thu, Sep 24, 2020 at 12:01 PM Thomas Schüttenberg <thomas at qgis.de>
> wrote:
> >> Hi!
> >> I just realized that numeric values (from a PostGIS table) are not
> displayed by a text edit widget in an attribute form, everything that is
> instead shown is 0 [zero].
> >> I switched from the default range widget to text edit widget, because I
> just want to show the attributes, read only, and this way it looks nicer to
> me. (BTW, the min/max values of the randfe widget are quite tremendous, see
> https://github.com/qgis/QGIS/issues/24725)
> >> To me this seems to be a bug and I suspect it to be related to
> localization (de_DE) issues which are themselves numerous. Therefore I
> wanted to check if anybody here knows an already existing/open bug report
> on this, because I did not find something exactly fitting. - Otherwise I
> will file a new one.
> > Please file a new ticket, can you also check if with en_US locale the
> > issue is still there?
> >> I tested on Windows with QGIS 3.4.12, 3.10.9 and 3.14.1.
> >> Cheers
> >> Thomas
> >> _______________________________________________
> >> QGIS-Developer mailing list
> >> QGIS-Developer at lists.osgeo.org
> >> List info: https://lists.osgeo.org/mailman/listinfo/qgis-developer
> >> Unsubscribe: https://lists.osgeo.org/mailman/listinfo/qgis-developer
URL: <http://lists.osgeo.org/pipermail/qgis-developer/attachments/20200926/7302b05e/attachment.html>
