[QGIS-Developer] DB Manager crash in master
Alessandro Pasotti
apasotti at gmail.com
Thu Sep 24 07:02:03 PDT 2020
On Thu, Sep 24, 2020 at 3:40 PM Paolo Cavallini <cavallini at faunalia.it> wrote:
> Hi Ale,
> I see in the ticket it is taken for granted that DB Manager is endo of
> life.
Don't worry, it will be maintained until we get feature parity.
> IMHO there is a considerable number of functions without which
> users will suffer. I believe it would be good to have a minimum set of
> functions to be ported, and a roadmap for it. Perhaps a QEP would be
> good here.
It was discussed several times during the last years, but here is at least one:
https://github.com/qgis/QGIS-Enhancement-Proposals/issues/171
Then we have n. 3 here:
http://blog.qgis.org/2020/02/23/reports-from-the-winning-grant-proposals-2019/
There is no roadmap because the work is long but here is a list of DB
manager features that are already available today in QGIS master in
the browser tree context menus:
- create a new schema
- delete a schema
- rename a schema
- create a new table/layer
- rename table/layer
- delete a table/layer
- truncate a table/layer
- refresh a materialized view
- list fields for a table/view
- add a new field
- delete a field
Also, some parts of DB-manager are using the new core QGIS connections
API instead of relying on Python packages, this is another important
step for the porting to C++.
Kind regards.
> Cheers.
> Il 24/09/20 08:53, Alessandro Pasotti ha scritto:
> > On Thu, Sep 24, 2020 at 8:50 AM Paolo Cavallini <cavallini at faunalia.it> wrote:
> >> it looks like, thanks.
> >> maybe it is worth the while to discuss about the future of integration
> >> pg-qgis?
> > Which is what?
> > This bug is about PyQGIS bindings in general and it is probably
> > upstream in SIP, it's not related to PG or DB-manager.
> >> cheers.
> >> Il 24/09/20 08:49, Alessandro Pasotti ha scritto:
> >>> On Thu, Sep 24, 2020 at 8:10 AM Paolo Cavallini <cavallini at faunalia.it> wrote:
> >>>> Hi all,
> >>>> I just compiled master, to test the patch on DB Manager from yesterday,
> >>>> but now qgis crashes systematically when I try to open a connection from
> >>>> DB Manager. No problem when opening from the browser.
> >>>> Does anyone confirm, or is it a local effect?
> >>> Hi Paolo,
> >>> You may be hitting this unresolved bug:
> >>> https://github.com/qgis/QGIS/issues/38393
> >> Paolo Cavallini
> >> www.faunalia.eu - QGIS.org
> >> training, support, development on QGIS, PostGIS and more
> Paolo Cavallini
> QGIS-Developer mailing list
> QGIS-Developer at lists.osgeo.org
> List info: https://lists.osgeo.org/mailman/listinfo/qgis-developer
> Unsubscribe: https://lists.osgeo.org/mailman/listinfo/qgis-developer
Alessandro Pasotti
QCooperative: www.qcooperative.net
ItOpen: www.itopen.it
