[QGIS-Developer] DB Manager crash in master
Paolo Cavallini
cavallini at faunalia.it
Thu Sep 24 07:09:52 PDT 2020
Fine, thanks a lot Alessandro. I use DB Manager quite extensively, both
for training and for real work, so probably I can offer a reasonable
user POV; I'm available for testing and discussion as needed.
Cheers.
Il 24/09/20 16:02, Alessandro Pasotti ha scritto:
> On Thu, Sep 24, 2020 at 3:40 PM Paolo Cavallini <cavallini at faunalia.it> wrote:
>> Hi Ale,
>> I see in the ticket it is taken for granted that DB Manager is endo of
>> life.
> Don't worry, it will be maintained until we get feature parity.
>> IMHO there is a considerable number of functions without which
>> users will suffer. I believe it would be good to have a minimum set of
>> functions to be ported, and a roadmap for it. Perhaps a QEP would be
>> good here.
> It was discussed several times during the last years, but here is at least one:
> https://github.com/qgis/QGIS-Enhancement-Proposals/issues/171
> Then we have n. 3 here:
> http://blog.qgis.org/2020/02/23/reports-from-the-winning-grant-proposals-2019/
> There is no roadmap because the work is long but here is a list of DB
> manager features that are already available today in QGIS master in
> the browser tree context menus:
> - create a new schema
> - delete a schema
> - rename a schema
> - create a new table/layer
> - rename table/layer
> - delete a table/layer
> - truncate a table/layer
> - refresh a materialized view
> - list fields for a table/view
> - add a new field
> - delete a field
> Also, some parts of DB-manager are using the new core QGIS connections
> API instead of relying on Python packages, this is another important
> step for the porting to C++.
> Kind regards.
>> Cheers.
>> Il 24/09/20 08:53, Alessandro Pasotti ha scritto:
>>> On Thu, Sep 24, 2020 at 8:50 AM Paolo Cavallini <cavallini at faunalia.it> wrote:
>>>> it looks like, thanks.
>>>> maybe it is worth the while to discuss about the future of integration
>>>> pg-qgis?
>>> Which is what?
>>> This bug is about PyQGIS bindings in general and it is probably
>>> upstream in SIP, it's not related to PG or DB-manager.
>>>> cheers.
>>>> Il 24/09/20 08:49, Alessandro Pasotti ha scritto:
>>>>> On Thu, Sep 24, 2020 at 8:10 AM Paolo Cavallini <cavallini at faunalia.it> wrote:
>>>>>> Hi all,
>>>>>> I just compiled master, to test the patch on DB Manager from yesterday,
>>>>>> but now qgis crashes systematically when I try to open a connection from
>>>>>> DB Manager. No problem when opening from the browser.
>>>>>> Does anyone confirm, or is it a local effect?
>>>>> Hi Paolo,
>>>>> You may be hitting this unresolved bug:
>>>>> https://github.com/qgis/QGIS/issues/38393
>>>> Paolo Cavallini
>>>> www.faunalia.eu - QGIS.org
>>>> training, support, development on QGIS, PostGIS and more
>> Paolo Cavallini
>> QGIS-Developer mailing list
>> QGIS-Developer at lists.osgeo.org
>> List info: https://lists.osgeo.org/mailman/listinfo/qgis-developer
>> Unsubscribe: https://lists.osgeo.org/mailman/listinfo/qgis-developer
Paolo Cavallini
