[QGIS-Developer] Make QGIS-Server more modular and specialized?
Andreas Neumann a.neumann at carto.net
Tue Sep 29 10:02:32 PDT 2020
Another scenario would be to have a specialized server only for GetPrint
requests. Those are often quite resource intensive (because of higher
dpi requests) and it would make sense, at a larger  installation - to
have dedicated instances for GetPrint only.
Andreas
On 2020-09-29 18:48, Andreas Neumann wrote:
> Dear QGIS (Server) devs,
> I wonder if it would be possible to make QGIS server more "modular" in a future version? I mean that at compile time you could decide which services should be enabled and which not? Example: if you are only interested in WMS, could you switch off all the other services?
> Another usage scenario: a larger installation of QGIS server might want to separate server instances for WMS, WFS or other services and assign different resources to it.
> Also, would it be possible to make QGIS Server a bit leaner/smaller/faster that way - or is the stuff the makes QGIS Server "fat" mainly the qt dependencies?
> Thanks for the discussion,
> Andreas
> QGIS-Developer mailing list
> QGIS-Developer at lists.osgeo.org
> List info: https://lists.osgeo.org/mailman/listinfo/qgis-developer
> Unsubscribe: https://lists.osgeo.org/mailman/listinfo/qgis-developer
URL: <http://lists.osgeo.org/pipermail/qgis-developer/attachments/20200929/63d55f71/attachment.html>
More information about the QGIS-Developer mailing list
