[QGIS-Developer] Make QGIS-Server more modular and specialized?
Andreas Neumann
a.neumann at carto.net
Tue Sep 29 12:37:30 PDT 2020
Hi Alessandro and Matthias,
Oh - I did not know about https://github.com/qgis/QGIS/pull/37682
How do I use this if I compile QGIS Server from source? How can I
disable/enable the components?
And yes - a "bad list" or "good list" would also be interesting to have.
Yes - probably as you say - not a speed gain to expect from it - and
probably size of qgis_mapserv.fcgi and memory consumption wouldn't
shrink much either?
About GetPrint: yes, we could reroute requests with a reverse proxy to
different instances, depending on the URL containing GetPrint commands
or not.
Thanks to both of you for your replies,
Andreas
Am 29.09.20 um 19:17 schrieb Alessandro Pasotti:
> On Tue, Sep 29, 2020 at 6:48 PM Andreas Neumann <a.neumann at carto.net> wrote:
>> Dear QGIS (Server) devs,
>> I wonder if it would be possible to make QGIS server more "modular" in a future version? I mean that at compile time you could decide which services should be enabled and which not? Example: if you are only interested in WMS, could you switch off all the other services?
> Hi Andreas,
> It is already possible, at the service level, we now have separate
> packages for the different services so you can actually install only
> what you want.
> See: https://github.com/qgis/QGIS/pull/37682
> But I doubt that you will gain any speed: the part of the code that
> decides what service is invoked is really fast compared to the rest of
> the processing.
> Another simple thing I was thinking about is to have a service
> "badlist" or a "goodlist" where we list in an environment variable the
> services that we want to be loaded (or not loaded)
> Cheers
>> Another usage scenario: a larger installation of QGIS server might want to separate server instances for WMS, WFS or other services and assign different resources to it.
>> Also, would it be possible to make QGIS Server a bit leaner/smaller/faster that way - or is the stuff the makes QGIS Server "fat" mainly the qt dependencies?
>> Thanks for the discussion,
>> Andreas
>> QGIS-Developer mailing list
>> QGIS-Developer at lists.osgeo.org
>> List info: https://lists.osgeo.org/mailman/listinfo/qgis-developer
>> Unsubscribe: https://lists.osgeo.org/mailman/listinfo/qgis-developer
