[QGIS-Developer] QGIS Compilation on Windows
rnathreddy at sanasw.com
Thu Apr 15 17:35:27 PDT 2021
Dear Jürgen,
Thank you very much for your quick reply. I have been struggling from
the past one month, installing multiple times on multiple machines. I
couldn't succeed.
As I understand
1) Use the QGIS version 3.16 repository
2) Use Microsoft Visual Studio 2019 compiler
3) Use the up to date Osgeo4w repositories using
http://download.osgeo.org/osgeo4w/testing/osgeo4w-setup.exe
I will try with the above and get back to you any query.
Thank you once again. Appreciate your help in this regard.
Regards
Raghunath
On 2021-04-15 12:25, Jürgen E. Fischer wrote:
> Hi Raghunath,
> On Thu, 15. Apr 2021 at 11:35:30 -0700, rnathreddy at sanasw.com wrote:
>> I am trying to build the QGIS on windows and followed the instructions
>> given
>> at
>> https://github.com/qgis/QGIS/blob/release-3_16/INSTALL.md#4-building-on-windows.
> That is not up-to-date as current master stopped building with the
> dependencies
> of the current OSGeo4W. 3.16 and 3.18 still do, but master doesn't.
> You can switch to dependencies from osgeo4w testing[0], that has the
> required more
> up-to-date dependencies. You also need to switch the MSVC 2019
> compiler.
> The build recipes for osgeo4w testing are in [1].
> Unfortunately I didn't yet get the git workflows builds[2] (or some
> alternative) to fly (runs out of space even w/o caches and takes ages
> to do
> so), so it's still done locally and documentation waits for a final
> path to
> materialize.
> What's in osgeo4w testing now is built locally from a cygwin env.
> Jürgen
> [0]
> https://lists.osgeo.org/pipermail/qgis-user/2021-February/048137.html
> [1]
> https://github.com/jef-n/OSGeo4W/blob/master/src/qgis-dev/osgeo4w/package.sh
> [2] https://github.com/jef-n/OSGeo4W/tree/workflows
