[QGIS-Developer] QGIS Compilation on Windows
Jürgen E. Fischer
jef at norbit.de
Fri Apr 16 01:49:08 PDT 2021
On Thu, 15. Apr 2021 at 17:35:27 -0700, rnathreddy at sanasw.com wrote:
> As I understand
> 1) Use the QGIS version 3.16 repository
> 2) Use Microsoft Visual Studio 2019 compiler
> 3) Use the up to date Osgeo4w repositories using http://download.osgeo.org/osgeo4w/testing/osgeo4w-setup.exe
Only for master the new repository is required - and in turn the new compiler.
For 3.16 or 3.18 you can stick with what's documented. But you can also
switch.
Jürgen
Jürgen E. Fischer norBIT GmbH Tel. +49-4931-918175-31
Dipl.-Inf. (FH) Rheinstraße 13 Fax. +49-4931-918175-50
Software Engineer D-26506 Norden https://www.norbit.de
QGIS release manager (PSC) Germany IRC: jef on FreeNode
Desc: not available
URL: <http://lists.osgeo.org/pipermail/qgis-developer/attachments/20210416/8b536f65/attachment.sig>
