[QGIS-Developer] How to transfer data between QGIS Python plugins?
Raymond Nijssen
r.nijssen at terglobo.nl
Thu Apr 22 04:27:40 PDT 2021
Hi Zac,
You can use:
qgis.utils.plugins
to get a dictionary with all active plugins.
To find out if another plugin is available:
'processing' in qgis.utils.plugins
And use it like:
processing_pl = qgis.utils.plugins['processing']
processing_pl.toolbox.searchBox.setText('overlay')
Hope this helps,
Raymond
On 22-04-2021 13:07, Zac Wang wrote:
> Hi all,
> Are there some ways to transfer data between different pyqgis plugins? I
> hope plugins share state.
> The only way I found is to make pluginA to be a child component of
> QgisApp(iface.mainWindow()).
> Then in another pluginB, call findChild() to get the object(pluginA) and
> connect its signal.
> This is a possible solution, but it's not easy to maintain because
> plugins are not initiated in the same file.
> Is there a better solution?
> Regards,
> Zac
> QGIS-Developer mailing list
> QGIS-Developer at lists.osgeo.org
> List info: https://lists.osgeo.org/mailman/listinfo/qgis-developer
> Unsubscribe: https://lists.osgeo.org/mailman/listinfo/qgis-developer
