[QGIS-Developer] How to transfer data between QGIS Python plugins?
Zac Wang zacwang15 at gmail.com
Thu Apr 22 05:09:09 PDT 2021
Hi guys,
Thank you for all your replies.
'qgis.utils.plugins' really resolves my problem.
This issue obsessed me for a few days, and your advice is fantastic.
I can't understand why there is no documentation for such a useful
functionality.
Anyway, thank you for your help. Appreciate it.
Cheers,
Zac
On Thu, 22 Apr 2021 at 22:01, Raymond Nijssen <r.nijssen at terglobo.nl> wrote:
> Hi Zac,
> You can use:
> qgis.utils.plugins
> to get a dictionary with all active plugins.
> To find out if another plugin is available:
> 'processing' in qgis.utils.plugins
> And use it like:
> processing_pl = qgis.utils.plugins['processing']
> processing_pl.toolbox.searchBox.setText('overlay')
> Hope this helps,
> Raymond
> On 22-04-2021 13:07, Zac Wang wrote:
> > Hi all,
> > Are there some ways to transfer data between different pyqgis plugins? I
> > hope plugins share state.
> > The only way I found is to make pluginA to be a child component of
> > QgisApp(iface.mainWindow()).
> > Then in another pluginB, call findChild() to get the object(pluginA) and
> > connect its signal.
> > This is a possible solution, but it's not easy to maintain because
> > plugins are not initiated in the same file.
> > Is there a better solution?
> > Regards,
> > Zac
> > QGIS-Developer mailing list
> > QGIS-Developer at lists.osgeo.org
> > List info: https://lists.osgeo.org/mailman/listinfo/qgis-developer
> > Unsubscribe: https://lists.osgeo.org/mailman/listinfo/qgis-developer
URL: <http://lists.osgeo.org/pipermail/qgis-developer/attachments/20210422/13b3a440/attachment-0001.html>
More information about the QGIS-Developer mailing list
