[QGIS-Developer] How to transfer data between QGIS Python plugins?
Etienne Trimaille etienne.trimaille at gmail.com
Thu Apr 22 20:08:01 PDT 2021
It also depends what you mean by "transferring data". It seems that you
mean Python code ? Not geospatial data ?
If you mean Python code, you can also have a look at the Processing
framework.
https://docs.qgis.org/3.16/en/docs/user_manual/processing/index.html
You can call Processing algorithm plugin A from plugin B by using
"processing.run("plugin_a_provider:name_of_algorithm")".
This will make you code available from the Processing graphical toolbox,
Modeler, etc as well.
Not recommended because others already gave the qgis.utils.plugins
dictionary, but you can do "from plugin_a.xxxx import yyy" from you plugin
B.
Le ven. 23 avr. 2021 à 04:43, Tobias Schmetzer <tschmetzer at gmx.de> a écrit :
> Hello Zac,
> I just saw you were helped and I'm happy the functionality solved your
> problem!
> If you feel there's a lack of documentation and you've got an idea how to
> improve it I think the best thing to do is to support this documentation
> with a contribution. This is how I started when I realised something was
> missing and I suggested to add this or that bit of information.
> It's easy to sign up on GitHub and make a suggestion. You can't damage
> anything. Everything will get reviewed and maybe discussed. There's also
> guidelines in the docs how to contribute.
> Best regards, Tobias
> 22.04.2021 14:09:30 Zac Wang <zacwang15 at gmail.com>:
> Hi guys,
> Thank you for all your replies.
> 'qgis.utils.plugins' really resolves my problem.
> This issue obsessed me for a few days, and your advice is fantastic.
> I can't understand why there is no documentation for such a useful
> functionality.
> Anyway, thank you for your help. Appreciate it.
> Cheers,
> Zac
> On Thu, 22 Apr 2021 at 22:01, Raymond Nijssen <r.nijssen at terglobo.nl>
> wrote:
>> Hi Zac,
>> You can use:
>> qgis.utils.plugins
>> to get a dictionary with all active plugins.
>> To find out if another plugin is available:
>> 'processing' in qgis.utils.plugins
>> And use it like:
>> processing_pl = qgis.utils.plugins['processing']
>> processing_pl.toolbox.searchBox.setText('overlay')
>> Hope this helps,
>> Raymond
>> On 22-04-2021 13:07, Zac Wang wrote:
>> > Hi all,
>> > Are there some ways to transfer data between different pyqgis plugins?
>> I
>> > hope plugins share state.
>> > The only way I found is to make pluginA to be a child component of
>> > QgisApp(iface.mainWindow()).
>> > Then in another pluginB, call findChild() to get the object(pluginA)
>> and
>> > connect its signal.
>> > This is a possible solution, but it's not easy to maintain because
>> > plugins are not initiated in the same file.
>> > Is there a better solution?
>> > Regards,
>> > Zac
>> > _______________________________________________
>> > QGIS-Developer mailing list
>> > QGIS-Developer at lists.osgeo.org
>> > List info: https://lists.osgeo.org/mailman/listinfo/qgis-developer
>> > Unsubscribe: https://lists.osgeo.org/mailman/listinfo/qgis-developer
URL: <http://lists.osgeo.org/pipermail/qgis-developer/attachments/20210423/444e1ce3/attachment.html>
More information about the QGIS-Developer mailing list
