[QGIS-Developer] How to transfer data between QGIS Python plugins?
Zac Wang zacwang15 at gmail.com
Thu Apr 22 21:58:33 PDT 2021
Hi Etienne,
Yes, you're right. I mean Python code.
Others' suggestions solved my problem. But it's good to know that I can
call another plugin using the Processing package.
Thank you.
Cheers,
Zac
On Fri, 23 Apr 2021 at 13:08, Etienne Trimaille <etienne.trimaille at gmail.com>
wrote:
> It also depends what you mean by "transferring data". It seems that you
> mean Python code ? Not geospatial data ?
> If you mean Python code, you can also have a look at the Processing
> framework.
> https://docs.qgis.org/3.16/en/docs/user_manual/processing/index.html
> You can call Processing algorithm plugin A from plugin B by using
> "processing.run("plugin_a_provider:name_of_algorithm")".
> This will make you code available from the Processing graphical toolbox,
> Modeler, etc as well.
> Not recommended because others already gave the qgis.utils.plugins
> dictionary, but you can do "from plugin_a.xxxx import yyy" from you plugin
> B.
> Le ven. 23 avr. 2021 à 04:43, Tobias Schmetzer <tschmetzer at gmx.de> a
> écrit :
>> Hello Zac,
>> I just saw you were helped and I'm happy the functionality solved your
>> problem!
>> If you feel there's a lack of documentation and you've got an idea how to
>> improve it I think the best thing to do is to support this documentation
>> with a contribution. This is how I started when I realised something was
>> missing and I suggested to add this or that bit of information.
>> It's easy to sign up on GitHub and make a suggestion. You can't damage
>> anything. Everything will get reviewed and maybe discussed. There's also
>> guidelines in the docs how to contribute.
>> Best regards, Tobias
>> 22.04.2021 14:09:30 Zac Wang <zacwang15 at gmail.com>:
>> Hi guys,
>> Thank you for all your replies.
>> 'qgis.utils.plugins' really resolves my problem.
>> This issue obsessed me for a few days, and your advice is fantastic.
>> I can't understand why there is no documentation for such a useful
>> functionality.
>> Anyway, thank you for your help. Appreciate it.
>> Cheers,
>> Zac
>> On Thu, 22 Apr 2021 at 22:01, Raymond Nijssen <r.nijssen at terglobo.nl>
>> wrote:
>>> Hi Zac,
>>> You can use:
>>> qgis.utils.plugins
>>> to get a dictionary with all active plugins.
>>> To find out if another plugin is available:
>>> 'processing' in qgis.utils.plugins
>>> And use it like:
>>> processing_pl = qgis.utils.plugins['processing']
>>> processing_pl.toolbox.searchBox.setText('overlay')
>>> Hope this helps,
>>> Raymond
>>> On 22-04-2021 13:07, Zac Wang wrote:
>>> > Hi all,
>>> > Are there some ways to transfer data between different pyqgis plugins?
>>> I
>>> > hope plugins share state.
>>> > The only way I found is to make pluginA to be a child component of
>>> > QgisApp(iface.mainWindow()).
>>> > Then in another pluginB, call findChild() to get the object(pluginA)
>>> and
>>> > connect its signal.
>>> > This is a possible solution, but it's not easy to maintain because
>>> > plugins are not initiated in the same file.
>>> > Is there a better solution?
>>> > Regards,
>>> > Zac
>>> > _______________________________________________
>>> > QGIS-Developer mailing list
>>> > QGIS-Developer at lists.osgeo.org
>>> > List info: https://lists.osgeo.org/mailman/listinfo/qgis-developer
>>> > Unsubscribe: https://lists.osgeo.org/mailman/listinfo/qgis-developer
URL: <http://lists.osgeo.org/pipermail/qgis-developer/attachments/20210423/42b33f29/attachment-0001.html>
More information about the QGIS-Developer mailing list
