[QGIS-Developer] [Qgis-user] Bug with GeoPackage and Expressions?
Matthias Kuhn
matthias at opengis.ch
Wed Jul 28 23:13:07 PDT 2021
Thanks for pointing that out.
In this case a sqlite compatible version (I think something like
`lower(NAME) LIKE '%bom%'` should work) is required.
Hope this helps
Matthias
On Thu, Jul 29, 2021 at 7:56 AM Andrea Giudiceandrea <andreaerdna at libero.it>
wrote:
> Il 29/07/2021 07:30, Matthias Kuhn ha scritto:
> > Can you fill a bug for this? The expression compiler in QGIS should not
> > forward it to ogr/gpkg/sqlite in this case.
> > Matthias
> The Query Builder documentation [1] states that:
> "The filter is made at the data provider (OGR, PostgreSQL, MSSQL…)
> level. So the syntax depends on the data provider (DateTime is for
> instance not supported for the ESRI Shapefile format)"
> So I think the reported behaviour is expected.
> Regards.
> Andrea
> [1]
> https://docs.qgis.org/3.16/en/docs/user_manual/working_with_vector/vector_properties.html#query-builder
> QGIS-Developer mailing list
> QGIS-Developer at lists.osgeo.org
> List info: https://lists.osgeo.org/mailman/listinfo/qgis-developer
> Unsubscribe: https://lists.osgeo.org/mailman/listinfo/qgis-developer
URL: <http://lists.osgeo.org/pipermail/qgis-developer/attachments/20210729/b5e8965b/attachment.html>
