[QGIS-Developer] Temporal Controller: Selection by Expression over non filtered data?
Richard Duivenvoorde
rdmailings at duif.net
Thu Jun 17 11:54:02 PDT 2021
Hi Devs,
Having a Temporal controlled dataset, I created a selection (using an expression) in one of the timeframes and created a (zero sized) buffer around it. Strange thing: the buffer was bigger then my (visible) selection...
Disabling the Temporal controller it thus appeared that the 'selection by expression' apparently does NOT take the temporal controller into account, which I think is intuitively it should?
IF you create a FILTER, and then do a selection, when you clear the filter, the selection is cleared: so different behaviour then controller.
FYI my usecase: we have these in time modelled clouds (with potentially dangerous chemicals in it) and want to see (on a certain timeframe) where the modelled values exceed certain health limits...
Should I create an issue?
Regards,
