[QGIS-Developer] QGIS Server: default values for GetLegendGraphics (fonts, symbol sizes, etc.)
Andreas Neumann
a.neumann at carto.net
Thu Jun 17 23:51:14 PDT 2021
Hi Jorge,
Thank you for your reply.
Do you know where in the QGIS project these LegendGraphic or legend
style settings would be configured/stored?
Or could one use the .ini file to store such settings globally?
Your suggestion about Apache rewrite rules might be a good workaround
for now, but it would be nice being able to set this through other
means, ideally globally for all projects.
Thanks for this discussion!
Andreas
On 2021-06-17 18:24, Jorge Gustavo Rocha wrote:
> Hi Andreas,
> The default values are in fact the values used in the QGIS project.
> These GetLegendGraphics parameters are used to overwrite those default
> settings.
> These are parameters and are not read from the environment. It should
> not be difficult to read them from the environment too, but it requires
> some additional logic on the server side.
> Some time ago, in our local municipality, I added some rewrite rules to
> Apache to use the same font in each GetLegendGraphics request, since
> not
> all people were using the same font on QGIS projects. The rewrite just
> adds
> &TRANSPARENT=true&ITEMFONTFAMILY=FreightSans&LAYERFONTFAMILY=FreightSans
> to each GetLengenGraphic request. The legend was much more uniform with
> this simple rewrite.
> As a workaround, I suggest something like these rewrite rules on the
> server side.
> Regards,
> Jorge
> On 17/06/21 16:33, Andreas Neumann wrote:
>> Hi,
>> I have a question regarding the default values for changing the look
>> and
>> feel of GetLegendGraphics as described at
>> https://docs.qgis.org/3.16/en/docs/server_manual/services.html#getlegendgraphics
>> <https://docs.qgis.org/3.16/en/docs/server_manual/services.html#getlegendgraphics>
>> (e.g. LAYERFONTFAMILY, SYMBOLWIDTH, etc.).
>> Is there a way to specify "default" values for these settings, e.g.
>> in
>> an environment variable or through other means?
>> Thank you if you know anything about it.
>> Andreas
>> QGIS-Developer mailing list
>> QGIS-Developer at lists.osgeo.org
>> List info: https://lists.osgeo.org/mailman/listinfo/qgis-developer
>> Unsubscribe: https://lists.osgeo.org/mailman/listinfo/qgis-developer
> J. Gustavo
> Jorge Gustavo Rocha
> Departamento de Informática
> Universidade do Minho
> 4710-057 Braga
> Gabinete 3.29 (Piso 3)
> Tel: +351 253604480
> Fax: +351 253604471
> Móvel: +351 910333888
> skype: nabocudnosor
URL: <http://lists.osgeo.org/pipermail/qgis-developer/attachments/20210618/9f5106a5/attachment-0001.html>
