[QGIS-Developer] Earth, Sun, Moon & Planets Plugin
Tim Sutton
tim at kartoza.com
Sun Jun 20 05:04:34 PDT 2021
Hi
On Wed, Jun 9, 2021 at 2:48 PM C Hamilton <adenaculture at gmail.com> wrote:
> Tim,
> Thanks for the suggestions. I will look into the temporal controller.
> As you know I like having the plugins self contained so that they run
> immediately. I have struggled with this issue in this case because there
> are no astronomical libraries that I can do this with, at least ones that
> are highly accurate and use ephemeris data rather than less accurate,
> simplified mathematical equations. I try to go for accuracy.
> For testing I will release a self contained windows version, but other
> users will need to pip install skyfield. In the case of the Date/Time Tools
> plugin I made it self contained so that the user didn't need to pip install
> anything, but that is what made it so large. It is reasonable for the user
> to download the ephemeris data separately. I may be able to extract a small
> set of the data that is within the 10 mb limit so that it is shipped with
> the plugin so that it works immediately. It just won't have a large date
> span, but if they are having to pip install skyfield, it is not going to be
> any more difficult to download the ephemeris data.
Another option to consider is to build an NSIS installer for your plugin. I
used to do this in the past for InaSAFE (see
https://github.com/inasafe/inasafe/blob/develop/scripts/windows-install-builder.nsi)
though I haven't maintained it so I don't know how well the approach still
works - it would need some tweaking to figure out which profile to install
the plugin into. Theoretically you could make one installer per platform
with all the binary bits encapsulated and then prompt the user to grab the
appropriate installer for their OS.
Regards
Tim
> I think it would be good for QGIS to have some astronomical libraries
> included. I've already had people express interest in this capability, but
> we will see how much overall interest there is in this plugin. It will get
> more acceptance if people do not need to pip install anything.
> Astropy is the most active and complex astronomy library. I chose not to
> use it because I didn't think it was needed for QGIS. I used Skyfield
> instead. It has the necessary functionality that I think is needed for QGIS
> projects. It is a modernized version of PyEphem by the same author and is
> recommended by the author over PyEphem.
> Thanks for your continued support,
> Calvin
> On Sat, Jun 5, 2021 at 1:04 PM Tim Sutton <tim at kartoza.com> wrote:
>> Hi
>> Wow that looks beautiful! A couple of thoughts:
>> 1) Rather than implementing your own slider logic I wonder if you could
>> hook in to the temporal controller?
>> 2) For platform specific components the normal practice is to a)
>> communicate with the plugins reviewers about why this is needed so that
>> they don't pre-emptively reject your plugin and b) normally pull down the
>> platform specific components as a post install step. I expect you will get
>> some resistance to adding a new dependency to QGIS core unless that
>> dependency is broadly useful, but you may be able to convince Jurgen and
>> Peter to bundle it into the Windows and macOS installers respectively.
>> 3) For that 100mb blob, similar to our discussion on the timezone work
>> you were doing, the preferred approach would be to fetch it as a
>> post-install download the first time you use the plugin.
>> Thanks for making such interesting plugins!
>> Regards
>> Tim
Tim Sutton
Visit http://kartoza.com to find out about open source:
* Desktop GIS programming services
* Geospatial web development
* GIS Training
* Consulting Services
Tim is a member of the QGIS Project Steering Committee
URL: <http://lists.osgeo.org/pipermail/qgis-developer/attachments/20210620/4cc86ccb/attachment.html>
