[QGIS-Developer] Run failed: Build Docker images for current branches
Matthias Kuhn matthias at opengis.ch
Wed Mar 10 01:04:33 PST 2021
Hi Tobias
Looks like actions that are meant to be run on the main repository got
activated on your fork of QGIS.
Not sure exactly when this happened, it might be when you push the master
branch from the main repo to yours.
Actions can disabled here:
https://github.com/tschmetzer/QGIS/settings/actions
Matthias
On Wed, Mar 10, 2021 at 9:35 AM Tobias Schmetzer <tschmetzer at gmx.de> wrote:
> Hello,
> sorry to disturb with a maybe simple problem (I already searched the
> mailing list of the past months). In my respository there seems a scheduled
> action task to be executed. For 13 days I've been receiving emails telling
> me about failed Docker images builds. I tried to google about the Docker
> images problem but the only things I found were about setting up these
> images on a build server.
> I thought maybe I missed an update so I rebased/merged from
> upstream/master into my respository but the problem persists. Did I miss
> something or how can I handle the action task failure?
> There seems to be a workflow file the task is using that I never changed:
> github/workflows/build-docker.yml
> Do I need to adapt it in some way and why now?
> This is an excerpt of one of the three branches (3.16, 3.18, master) that
> the task tells me are failing:
> *> Run actions/checkout at v2 *
> *Syncing repository: tschmetzer/QGIS *
> *> Getting Git version info *
> *Deleting the contents of '/home/runner/work/QGIS/QGIS' *
> *>Initializing the repository *
> *> Disabling automatic garbage collection *
> *> Setting up auth *
> *v Fetching the repository *
> */usr/bin/git -c protocol.version=2 fetch --no-tags --prune --progress
> --no-recurse-submodules --depth=1 origin
> +refs/heads/release-3_18*:refs/remotes/origin/release-3_18*
> +refs/tags/release-3_18*:refs/tags/release-3_18* *
> *The process '/usr/bin/git' failed with exit code 1 *
> *Waiting 17 seconds before trying again *
> *Waiting 13 seconds before trying again *
> *Error: The process '/usr/bin/git' failed with exit code 1*
> Thanks in advance for any hints to solve this!
> Regards, Tobias
> QGIS-Developer mailing list
> QGIS-Developer at lists.osgeo.org
> List info: https://lists.osgeo.org/mailman/listinfo/qgis-developer
> Unsubscribe: https://lists.osgeo.org/mailman/listinfo/qgis-developer
URL: <http://lists.osgeo.org/pipermail/qgis-developer/attachments/20210310/37b6458f/attachment.html>
More information about the QGIS-Developer mailing list
