[QGIS-Developer] Run failed: Build Docker images for current branches
Denis Rouzaud denis.rouzaud at gmail.com
Wed Mar 10 01:04:38 PST 2021
Hi Tobias,
The workflow is not meant to be run from your repo.
You can deactivate the workflows in your repo settings.
But, to be safe, I just changed the workflow so that it should not run
anymore on forks:
https://github.com/qgis/QGIS/commit/84b3cb1870a49e6dfdd95bc20c80cf2398b35cfc
Best regards,
Denis
Le mer. 10 mars 2021 à 09:35, Tobias Schmetzer <tschmetzer at gmx.de> a écrit :
> Hello,
> sorry to disturb with a maybe simple problem (I already searched the
> mailing list of the past months). In my respository there seems a scheduled
> action task to be executed. For 13 days I've been receiving emails telling
> me about failed Docker images builds. I tried to google about the Docker
> images problem but the only things I found were about setting up these
> images on a build server.
> I thought maybe I missed an update so I rebased/merged from
> upstream/master into my respository but the problem persists. Did I miss
> something or how can I handle the action task failure?
> There seems to be a workflow file the task is using that I never changed:
> github/workflows/build-docker.yml
> Do I need to adapt it in some way and why now?
> This is an excerpt of one of the three branches (3.16, 3.18, master) that
> the task tells me are failing:
> *> Run actions/checkout at v2 *
> *Syncing repository: tschmetzer/QGIS *
> *> Getting Git version info *
> *Deleting the contents of '/home/runner/work/QGIS/QGIS' *
> *>Initializing the repository *
> *> Disabling automatic garbage collection *
> *> Setting up auth *
> *v Fetching the repository *
> */usr/bin/git -c protocol.version=2 fetch --no-tags --prune --progress
> --no-recurse-submodules --depth=1 origin
> +refs/heads/release-3_18*:refs/remotes/origin/release-3_18*
> +refs/tags/release-3_18*:refs/tags/release-3_18* *
> *The process '/usr/bin/git' failed with exit code 1 *
> *Waiting 17 seconds before trying again *
> *Waiting 13 seconds before trying again *
> *Error: The process '/usr/bin/git' failed with exit code 1*
> Thanks in advance for any hints to solve this!
> Regards, Tobias
> QGIS-Developer mailing list
> QGIS-Developer at lists.osgeo.org
> List info: https://lists.osgeo.org/mailman/listinfo/qgis-developer
> Unsubscribe: https://lists.osgeo.org/mailman/listinfo/qgis-developer
URL: <http://lists.osgeo.org/pipermail/qgis-developer/attachments/20210310/92d96bcb/attachment-0001.html>
More information about the QGIS-Developer mailing list
