[QGIS-Developer] Disable/commenting provider filter?
Jorge Gustavo Rocha
jgr at di.uminho.pt
Tue May 11 13:45:55 PDT 2021
Another workaround is layer duplication. You can have an instance
without filters and one with filters. Then switch between them.
But a filter history for the layer (like the one in the old DB manager
where you can save queries), could be useful.
Regards,
Jorge
On 11/05/21 21:31, Alexandre Neto wrote:
> Bad workaround then :-p
> A terça, 11/05/2021, 21:10, Matthias Kuhn <matthias at opengis.ch
> <mailto:matthias at opengis.ch>> escreveu:
> Unfortunately, that won't work, filters are not part of the style.
> On Tue, May 11, 2021 at 9:24 PM Alexandre Neto
> <senhor.neto at gmail.com <mailto:senhor.neto at gmail.com>> wrote:
> As an workaround, can't you just create a new style and remove
> the filter? Then go back to the default style?
> Obviously a checkbox would be much more user friendly.
> Alexandre Neto
> A terça, 11/05/2021, 09:52, Andreas Neumann <andreas at qgis.org
> <mailto:andreas at qgis.org>> escreveu:
> Hi Richard,
> Yes - I think this would be very useful. I would prefer the
> checkbox for enabling/disabling without losing the filter
> string.
> Thanks,
> Andreas
> On Mon, 10 May 2021 at 16:41, Richard Duivenvoorde
> <rdmailings at duif.net <mailto:rdmailings at duif.net>> wrote:
> Hi List,
> When I add a filter to a layer, I often want to
> temporarily disable that
> filter (just to see what the full view is).
> Working a lot with sql scripts recently, in which you
> comment out (a
> part) of a sql query by putting '--' in front of it, I
> tried that also
> in the Query builder, and though it looks like I'm
> commenting out my
> query (the query is greyed-out), it's not working, I get
> a parsing
> error.
> So usability question:
> - would other people be interested in temporarily
> disabling the layer
> filter query, or am I the only one :-)
> If yes:
> - should it be implemented by 'commenting' out part of
> the query?
> - or should there be some 'temporarily disable' checkbox
> in the query
> builder)
> - should it be a context menu (either the layer, or the
> little filter
> overlay icon in the layermanager)
> Tech question:
> - any forseeing issues with such thing?
> Regards,
> QGIS-Developer mailing list
> QGIS-Developer at lists.osgeo.org
> <mailto:QGIS-Developer at lists.osgeo.org>
> List info:
> https://lists.osgeo.org/mailman/listinfo/qgis-developer
> <https://lists.osgeo.org/mailman/listinfo/qgis-developer>
> Unsubscribe:
> Andreas Neumann
> QGIS.ORG <http://QGIS.ORG> board member (treasurer)
> List info:
> Unsubscribe:
> List info:
> Unsubscribe:
> List info: https://lists.osgeo.org/mailman/listinfo/qgis-developer
> Unsubscribe: https://lists.osgeo.org/mailman/listinfo/qgis-developer
J. Gustavo
Jorge Gustavo Rocha
Departamento de Informática
Universidade do Minho
4710-057 Braga
Gabinete 3.29 (Piso 3)
Tel: +351 253604480
Fax: +351 253604471
Móvel: +351 910333888
skype: nabocudnosor
