[QGIS-Developer] Build issue and SIP_CONCAT_PARTS
Matthias Kuhn
matthias at opengis.ch
Mon May 31 00:27:32 PDT 2021
Hi Julien,
I could fix these in the past by adding the appropriate ModuleHeaderCode,
it requires looking into the generated sip_corepart file to find out which
class was responsible.
#ifdef SIP_RUN
% ModuleHeaderCode
#include "qgsoptionalexpression.h"
% End
#endif
Hope this helps
Matthias
On Mon, May 31, 2021 at 9:11 AM Julien Cabieces <
julien.cabieces at oslandia.com> wrote:
> Hy Nyall,
> Yes, I am already rebased on master. And I saw you change it to 13, so I
> try to increase it to 14... and it works for core but not analysis.
> For now, I'm gonna stick with a concat value of 1, and when I'll be
> ready to push, I'll search for a value which works.
> Thanks for your response.
> Kind regards,
> Julien
> > On Wed, 26 May 2021 at 23:49, Julien Cabieces
> > <julien.cabieces at oslandia.com> wrote:
> >> Hi devs,
> >> I'm working on a new QGIS feature and wanted to add a new API in core
> module. I get a strange error when building, on a class not related to what
> I am adding.
> /home/julien/work/QGIS/build_debug/python/core/sip_corepart11.cpp:272:67:
> error: no type named 'QgsOptionalQgsExpressionBase' in the global
> namespace; did you mean 'QgsOptionalExpression'?
> >> ::QgsOptionalQgsExpressionBase *sipCpp = reinterpret_cast<
> ::QgsOptionalQgsExpressionBase *>(sipGetCppPtr((sipSimpleWrapper
> *)sipSelf,sipType_QgsOptionalQgsExpressionBase));
> >> It said that QgsOptionalExpressionBase is not defined in
> >> sip_corepart_11.cpp, but the typedef is actually in sip_corepart_10.cpp,
> >> at the end of the file.
> > Are you based on a recent master branch? I had to bump the concat
> > parts to 13 recently to avoid this exact issue. Perhaps if you rebase
> > it will be fixed already.
> >> From what I understand, CMakeList variable SIP_CONCAT_PARTS allows to
> >> split the SIP generated cpp code in several module, but in this case it
> >> looks like split happens on a bad location (typedef on one side, part of
> >> the code on the other side).
> > Yeah, it's sip being fragile. We've hit this many times in past, and
> > the solution each time is to increase the number of parts by 1.
> >> If I set SIP_CONCAT_PARTS to 1, it works.
> >> Has anyone already facing this kind of issue? Is there some sort of
> instruction that I should be aware of to solve this?
> >> I'm on master, Debian Bullseye, SIP 4.19.25
> >> Kind regards,
> >> Julien
> >> _______________________________________________
> >> QGIS-Developer mailing list
> >> QGIS-Developer at lists.osgeo.org
> >> List info: https://lists.osgeo.org/mailman/listinfo/qgis-developer
> >> Unsubscribe: https://lists.osgeo.org/mailman/listinfo/qgis-developer
URL: <http://lists.osgeo.org/pipermail/qgis-developer/attachments/20210531/170911cc/attachment.html>
