[QGIS-Developer] QGIS 3.22 compilation on windows 10 with MSVC 2019
Jürgen E. Fischer
jef at norbit.de
Tue Nov 2 08:33:33 PDT 2021
On Tue, 02. Nov 2021 at 14:09:09 +0530, Paul N wrote:
> Hi, I have tried to run your msvc-env.bat and checked the system path line
> by line.
> But still having the error as below:
> dbghelp.dll not found
> C:\Program Files (x86)\ArcGIS\Desktop10.8\bin\dbghelp.dll
Looks like the SDK is incomplete:
set SETUPAPI_LIBRARY=%PF86%\Windows Kits\10\Lib\%VCSDK%\um\x64\SetupAPI.Lib
set DBGHLP_PATH=%PF86%\Windows Kits\10\Debuggers\x64
if not exist "%SETUPAPI_LIBRARY%" (
echo SETUPAPI_LIBRARY not found
dir /s /b "%PF86%\setupapi.lib"
goto error
if not exist "%DBGHLP_PATH%\dbghelp.dll" (
echo dbghelp.dll not found
dir /s /b "%PF86%\dbghelp.dll" "%PF86%\symsrv.dll"
goto error
So you apparently have SetupAPI.Lib, but not dbghelp.dll in
C:\Program Files (x86)\Windows Kits\10
https://github.com/jef-n/QGIS/commits/workflows-msvc includes some updates to
INSTALL[0]. The merges for OSGeo4W v2 are still pending (at the time both ltr
and latest release were built for old and osgeo4w v2; now only the current ltr
is still built for old osgeo4w).
Jürgen
[0] https://github.com/jef-n/QGIS/blob/7401e795a6a0eee82b86f4d78026f4635790c43f/INSTALL
Jürgen E. Fischer norBIT GmbH Tel. +49-4931-918175-31
Dipl.-Inf. (FH) Rheinstraße 13 Fax. +49-4931-918175-50
Software Engineer D-26506 Norden https://www.norbit.de
QGIS release manager (PSC) Germany IRC: jef on Libera|OFTC
Desc: not available
URL: <http://lists.osgeo.org/pipermail/qgis-developer/attachments/20211102/bfe02638/attachment.sig>
