[QGIS-Developer] QGIS 3.22 compilation on windows 10 with MSVC 2019
Paul N surveykshak at gmail.com
Tue Nov 9 01:37:34 PST 2021
Thanks for your support. I am able to install the Debugger in Window Kit/10
and now its working. But after running the configure.bat I got the
unexpected error.
** Visual Studio 2019 Developer Command Prompt v16.11.5
** Copyright (c) 2021 Microsoft Corporation
[vcvarsall.bat] Environment initialized for: 'x64'
Microsoft Windows [Version 10.0.22000.282]
(c) Microsoft Corporation. All rights reserved.
E:\OSGeo4Wv2>cd\
E:\>cd Repositories\QGIS-release-3_22\ms-windows\osgeo4w
E:\Repositories\QGIS-release-3_22\ms-windows\osgeo4w>configonly.bat
BEGIN: 09-11-2021 14:56:07.78
CMAKE: 09-11-2021 14:56:08.26
*Studio was unexpected at this time.*
My batch file are attached as text file. Please help in identifying the
problem.
Thanks
On Tue, 2 Nov 2021 at 21:04, Jürgen E. Fischer <jef at norbit.de> wrote:
> On Tue, 02. Nov 2021 at 14:09:09 +0530, Paul N wrote:
> > Hi, I have tried to run your msvc-env.bat and checked the system path
> line
> > by line.
> > But still having the error as below:
> > dbghelp.dll not found
> > C:\Program Files (x86)\ArcGIS\Desktop10.8\bin\dbghelp.dll
> Looks like the SDK is incomplete:
> set SETUPAPI_LIBRARY=%PF86%\Windows Kits\10\Lib\%VCSDK%\um\x64\SetupAPI.Lib
> set DBGHLP_PATH=%PF86%\Windows Kits\10\Debuggers\x64
> if not exist "%SETUPAPI_LIBRARY%" (
>   echo SETUPAPI_LIBRARY not found
>   dir /s /b "%PF86%\setupapi.lib"
>   goto error
> if not exist "%DBGHLP_PATH%\dbghelp.dll" (
>   echo dbghelp.dll not found
>   dir /s /b "%PF86%\dbghelp.dll" "%PF86%\symsrv.dll"
>   goto error
> So you apparently have SetupAPI.Lib, but not dbghelp.dll in
> C:\Program Files (x86)\Windows Kits\10
> https://github.com/jef-n/QGIS/commits/workflows-msvc includes some
> updates to
> INSTALL[0].  The merges for OSGeo4W v2 are still pending (at the time both
> ltr
> and latest release were built for old and osgeo4w v2; now only the current
> ltr
> is still built for old osgeo4w).
> Jürgen
> [0]
> https://github.com/jef-n/QGIS/blob/7401e795a6a0eee82b86f4d78026f4635790c43f/INSTALL
> Jürgen E. Fischer           norBIT GmbH             Tel. +49-4931-918175-31
> Dipl.-Inf. (FH)             Rheinstraße 13          Fax. +49-4931-918175-50
> Software Engineer           D-26506 Norden
> https://www.norbit.de
> QGIS release manager (PSC)  Germany                 IRC: jef on Libera|OFTC
> QGIS-Developer mailing list
> QGIS-Developer at lists.osgeo.org
> List info: https://lists.osgeo.org/mailman/listinfo/qgis-developer
> Unsubscribe: https://lists.osgeo.org/mailman/listinfo/qgis-developer
URL: <http://lists.osgeo.org/pipermail/qgis-developer/attachments/20211109/02156579/attachment-0001.html>
@echo off
REM ***************************************************************************
REM    msvc-env.cmd
REM    ---------------------
REM    begin                : June 2018
REM    copyright            : (C) 2018 by Juergen E. Fischer
REM    email                : jef at norbit dot de
REM *        *
REM *   This program is free software; you can redistribute it and/or modify  *
REM *   it under the terms of the GNU General Public License as published by  *
REM *   the Free Software Foundation; either version 2 of the License, or     *
REM *   (at your option) any later version.                                   *
REM *        *
if not "%PROGRAMFILES(X86)%"=="" set PF86=%PROGRAMFILES(X86)%
if "%PF86%"=="" set PF86=%PROGRAMFILES%
if "%PF86%"=="" (echo PROGRAMFILES not set & goto error)
if "%VCSDK%"=="" set VCSDK=10.0.18362.0
set ARCH=%1
if "%ARCH%"=="x86" goto x86
if "%ARCH%"=="x86_64" goto x86_64
goto usage
:x86
set VCARCH=x86
set SETUPAPI_LIBRARY=%PF86%\Windows Kits\10\Lib\%VCSDK%\um\x86\SetupAPI.Lib
set DBGHLP_PATH=%PF86%\OSGeo4W_testing
goto archset
:x86_64
set VCARCH=amd64
:archset
  goto error
  goto error
if "%CC%"=="" set CC=cl.exe
if "%CXX%"=="" set CXX=cl.exe
if "%OSGEO4W_ROOT%"=="" (
	if "%ARCH%"=="x86" (
		set OSGEO4W_ROOT=E:\OSGeo4Wv2
	) else (
if not exist "%OSGEO4W_ROOT%\bin\o4w_env.bat" (echo o4w_env.bat not found & goto error)
call "%OSGEO4W_ROOT%\bin\o4w_env.bat"
call "%OSGEO4W_ROOT%\bin\py3_env.bat"
call "%OSGEO4W_ROOT%\bin\qt5_env.bat"
for %%e in (Community Professional Enterprise) do if exist "%PF86%\Microsoft Visual Studio\2019\%%e" set vcdir=%PF86%\Microsoft Visual Studio\2019\%%e
if "%vcdir%"=="" (echo Visual C++ not found & goto error)
set VS160COMNTOOLS=%vcdir%\Common7\Tools
call "%vcdir%\VC\Auxiliary\Build\vcvarsall.bat" %VCARCH%
path %path%;%vcdir%\VC\bin
set GRASS7=
if exist %OSGEO4W_ROOT%\bin\grass74.bat set GRASS7=%OSGEO4W_ROOT%\bin\grass74.bat
if exist %OSGEO4W_ROOT%\bin\grass76.bat set GRASS7=%OSGEO4W_ROOT%\bin\grass76.bat
if exist %OSGEO4W_ROOT%\bin\grass78.bat set GRASS7=%OSGEO4W_ROOT%\bin\grass78.bat
if "%GRASS7%"=="" (echo GRASS7 not found & goto error)
for /f "usebackq tokens=1" %%a in (`%GRASS7% --config path`) do set GRASS_PREFIX=%%a
set PYTHONPATH=
if exist "%PROGRAMFILES%\CMake\bin" path %PATH%;%PROGRAMFILES%\CMake\bin
if exist "%PF86%\CMake\bin" path %PATH%;%PF86%\CMake\bin
if exist e:\cygwin64\bin path %PATH%;e:\cygwin64\bin
if exist e:\cygwin\bin path %PATH%;e:\cygwin\bin
set LIB=%LIB%;%OSGEO4W_ROOT%\apps\Qt5\lib;%OSGEO4W_ROOT%\lib
set INCLUDE=%INCLUDE%;%OSGEO4W_ROOT%\apps\Qt5\include;%OSGEO4W_ROOT%\include
goto end
:usage
echo usage: %0 [x86^|x86_64]
echo sample: %0 x86_64
exit /b 1
:error
echo ENV ERROR %ERRORLEVEL%: %DATE% %TIME%
exit /b 1
:end
@echo off
REM    package-nightly.cmd
REM    begin                : January 2011
REM    copyright            : (C) 2011 by Juergen E. Fischer
REM *        *
REM *        *
setlocal enabledelayedexpansion
set VERSION=%1
set PACKAGE=%2
set PACKAGENAME=%3
set ARCH=%4
set SHA=%5
set SITE=%6
if "%VERSION%"=="" goto usage
if "%PACKAGE%"=="" goto usage
if "%PACKAGENAME%"=="" goto usage
if "%ARCH%"=="" goto usage
if not "%SHA%"=="" set SHA=-%SHA%
if "%SITE%"=="" set SITE=qgis.org
if "%TARGET%"=="" set TARGET=Nightly
if "%BUILDNAME%"=="" set BUILDNAME=%PACKAGENAME%-%VERSION%%SHA%-%TARGET%-VC16-%ARCH%
if "%BUILDDIR%"=="" set BUILDDIR=%CD%\build-%PACKAGENAME%-%ARCH%
if not exist "%BUILDDIR%" mkdir %BUILDDIR%
if not exist "%BUILDDIR%" (echo could not create build directory %BUILDDIR% & goto error)
call msvc-env.bat %ARCH%
call gdal-dev-env.bat
set O4W_ROOT=%OSGEO4W_ROOT:\=/%
set LIB_DIR=%O4W_ROOT%
	set CMAKE_OPT=^
		-D SPATIALINDEX_LIBRARY=%O4W_ROOT%/lib/spatialindex-32.lib
) else (
	set CMAKE_OPT=^
		-D SPATIALINDEX_LIBRARY=%O4W_ROOT%/lib/spatialindex-64.lib ^
		-D CMAKE_INSTALL_SYSTEM_RUNTIME_LIBS_NO_WARNINGS=TRUE
for %%i in ("%GRASS_PREFIX%") do set GRASS7_VERSION=%%~nxi
set GRASS_VERSIONS=%GRASS7_VERSION%
set TAR=tar.exe
if exist "e:\cygwin\bin\tar.exe" set TAR=e:\cygwin\bin\tar.exe
if exist "e:\cygwin64\bin\tar.exe" set TAR=e:\cygwin64\bin\tar.exe
set BUILDCONF=RelWithDebInfo
cd ..\..
set SRCDIR=%CD%
if "%BUILDDIR:~1,1%"==":" %BUILDDIR:~0,2%
cd %BUILDDIR%
set PKGDIR=%OSGEO4W_ROOT%\apps\%PACKAGENAME%
if exist repackage goto package
if not exist build.log goto build
REM
REM try renaming the logfile to see if it's locked
REM
if exist build.tmp del build.tmp
if exist build.tmp (echo could not remove build.tmp & goto error)
ren build.log build.tmp
if exist build.log goto locked
if not exist build.tmp goto locked
ren build.tmp build.log
if exist build.tmp goto locked
if not exist build.log goto locked
goto build
:locked
echo Logfile locked
goto error
:build
echo BEGIN: %DATE% %TIME%
set >buildenv.log
if exist qgsversion.h del qgsversion.h
if exist CMakeCache.txt if exist skipcmake goto skipcmake
touch %SRCDIR%\CMakeLists.txt
echo CMAKE: %DATE% %TIME%
if "%CMAKEGEN%"=="" set CMAKEGEN=-G Ninja
if "%OSGEO4W_CXXFLAGS%"=="" set OSGEO4W_CXXFLAGS=/MD /Z7 /MP /Od /D NDEBUG
for %%i in (%PYTHONHOME%) do set PYVER=%%~ni
cmake %CMAKEGEN% ^
	-D CMAKE_CXX_COMPILER="%CXX:\=/%" ^
	-D CMAKE_C_COMPILER="%CC:\=/%" ^
	-D CMAKE_LINKER=link.exe ^
	-D CMAKE_CXX_FLAGS_RELWITHDEBINFO="%OSGEO4W_CXXFLAGS%" ^
	-D CMAKE_PDB_OUTPUT_DIRECTORY_RELWITHDEBINFO=%BUILDDIR%\apps\%PACKAGENAME%\pdb ^
	-D BUILDNAME="%BUILDNAME%" ^
	-D SITE="%SITE%" ^
	-D PEDANTIC=TRUE ^
	-D WITH_QSPATIALITE=TRUE ^
	-D WITH_SERVER=TRUE ^
	-D SERVER_SKIP_ECW=TRUE ^
	-D WITH_GRASS=TRUE ^
	-D WITH_3D=TRUE ^
	-D WITH_GRASS7=TRUE ^
	-D GRASS_PREFIX7=%GRASS_PREFIX:\=/% ^
	-D WITH_GLOBE=FALSE ^
	-D WITH_ORACLE=TRUE ^
	-D WITH_CUSTOM_WIDGETS=TRUE ^
	-D CMAKE_BUILD_TYPE=%BUILDCONF% ^
	-D CMAKE_CONFIGURATION_TYPES=%BUILDCONF% ^
	-D SETUPAPI_LIBRARY="%SETUPAPI_LIBRARY%" ^
	-D PROJ_LIBRARY=%O4W_ROOT%/apps/proj-dev/lib/proj.lib ^
	-D PROJ_INCLUDE_DIR=%O4W_ROOT%/apps/proj-dev/include ^
	-D GDAL_LIBRARY=%O4W_ROOT%/apps/gdal-dev/lib/gdal_i.lib ^
	-D GDAL_INCLUDE_DIR=%O4W_ROOT%/apps/gdal-dev/include ^
	-D GEOS_LIBRARY=%O4W_ROOT%/lib/geos_c.lib ^
	-D SQLITE3_LIBRARY=%O4W_ROOT%/lib/sqlite3_i.lib ^
	-D SPATIALITE_LIBRARY=%O4W_ROOT%/lib/spatialite_i.lib ^
	-D PYTHON_EXECUTABLE=%O4W_ROOT%/bin/python3.exe ^
	-D SIP_BINARY_PATH=%PYTHONHOME:\=/%/sip.exe ^
	-D PYTHON_INCLUDE_PATH=%PYTHONHOME:\=/%/include ^
	-D PYTHON_LIBRARY=%PYTHONHOME:\=/%/libs/%PYVER%.lib ^
	-D QT_LIBRARY_DIR=%O4W_ROOT%/lib ^
	-D QT_HEADERS_DIR=%O4W_ROOT%/apps/qt5/include ^
	-D CMAKE_INSTALL_PREFIX=%O4W_ROOT%/apps/%PACKAGENAME% ^
	-D FCGI_INCLUDE_DIR=%O4W_ROOT%/include ^
	-D FCGI_LIBRARY=%O4W_ROOT%/lib/libfcgi.lib ^
	-D QCA_INCLUDE_DIR=%OSGEO4W_ROOT%\apps\Qt5\include\QtCrypto ^
	-D QCA_LIBRARY=%OSGEO4W_ROOT%\apps\Qt5\lib\qca-qt5.lib ^
	-D QSCINTILLA_LIBRARY=%OSGEO4W_ROOT%\apps\Qt5\lib\qscintilla2.lib ^
	-D DART_TESTING_TIMEOUT=60 ^
	%CMAKE_OPT% ^
	%SRCDIR:\=/%
if errorlevel 1 (echo cmake failed & goto error)
if "%CONFIGONLY%"=="1" (echo Exiting after configuring build directory: %CD% & goto end)
:skipcmake
if exist ..\noclean (echo skip clean & goto skipclean)
echo CLEAN: %DATE% %TIME%
cmake --build %BUILDDIR% --target clean --config %BUILDCONF%
if errorlevel 1 (echo clean failed & goto error)
:skipclean
if exist ..\skipbuild (echo skip build & goto skipbuild)
echo ALL_BUILD: %DATE% %TIME%
cmake --build %BUILDDIR% --target %TARGET%Build --config %BUILDCONF%
set /P tag=<%BUILDDIR%\Testing\TAG
findstr "<Error>" %BUILDDIR%\Testing\%tag%\Build.xml >nul
if not errorlevel 1 (
	cmake --build %BUILDDIR% --target %TARGET%Submit --config %BUILDCONF%
	if errorlevel 1 echo SUBMITTING BUILD ERRORS WAS NOT SUCCESSFUL.
	echo build failed
	goto error
:skipbuild
if exist ..\skiptests goto skiptests
echo RUN_TESTS: %DATE% %TIME%
reg add "HKCU\Software\Microsoft\Windows\Windows Error Reporting" /v DontShow /t REG_DWORD /d 1 /f
set oldtemp=%TEMP%
set oldtmp=%TMP%
set oldpath=%PATH%
set TEMP=%TEMP%\%PACKAGENAME%-%ARCH%
set TMP=%TEMP%
if exist "%TEMP%" rmdir /s /q "%TEMP%"
mkdir "%TEMP%"
for %%g IN (%GRASS_VERSIONS%) do (
	set path=!path!;%OSGEO4W_ROOT%\apps\grass\%%g\lib
	set GISBASE=%OSGEO4W_ROOT%\apps\grass\%%g
PATH %path%;%BUILDDIR%\output\plugins
set QT_PLUGIN_PATH=%BUILDDIR%\output\plugins;%OSGEO4W_ROOT%\apps\qt5\plugins
if exist ..\testfailure del ..\testfailure
cmake --build %BUILDDIR% --target %TARGET%Test --config %BUILDCONF%
if errorlevel 1 (echo TESTS WERE NOT SUCCESSFUL. & echo %errorlevel% >..\testfailure)
set TEMP=%oldtemp%
set TMP=%oldtmp%
PATH %oldpath%
if errorlevel 1 echo TEST SUBMISSION WAS NOT SUCCESSFUL.
:skiptests
if exist ..\skippackage goto end
if exist "%PKGDIR%" (
	echo REMOVE: %DATE% %TIME%
	rmdir /s /q "%PKGDIR%"
echo INSTALL: %DATE% %TIME%
cmake --build %BUILDDIR% --target install --config %BUILDCONF%
if errorlevel 1 (echo INSTALL failed & goto error)
:package
echo PACKAGE: %DATE% %TIME%
cd ..
sed -e 's/@package@/%PACKAGENAME%/g' -e 's/@version@/%VERSION%/g' -e 's/@grassversions@/%GRASS_VERSIONS%/g' postinstall-dev.bat >%OSGEO4W_ROOT%\etc\postinstall\%PACKAGENAME%.bat
if errorlevel 1 (echo creation of desktop postinstall failed & goto error)
sed -e 's/@package@/%PACKAGENAME%/g' -e 's/@version@/%VERSION%/g' -e 's/@grassversions@/%GRASS_VERSIONS%/g' preremove-dev.bat >%OSGEO4W_ROOT%\etc\preremove\%PACKAGENAME%.bat
if errorlevel 1 (echo creation of desktop preremove failed & goto error)
sed -e 's/@package@/%PACKAGENAME%/g' -e 's/@version@/%VERSION%/g' designer.bat.tmpl >%OSGEO4W_ROOT%\bin\%PACKAGENAME%-designer.bat.tmpl
if errorlevel 1 (echo creation of designer template failed & goto error)
sed -e 's/@package@/%PACKAGENAME%/g' -e 's/@version@/%VERSION%/g' qgis.reg.tmpl >%PKGDIR%\bin\qgis.reg.tmpl
if errorlevel 1 (echo creation of registry template & goto error)
sed -e 's/@package@/%PACKAGENAME%/g' -e 's/@version@/%VERSION%/g' -e 's/^call py3_env.bat/call gdal-dev-py3-env.bat/' qgis.bat.tmpl >%OSGEO4W_ROOT%\bin\%PACKAGENAME%.bat.tmpl
if errorlevel 1 (echo creation of desktop template failed & goto error)
set batches=bin/%PACKAGENAME%.bat.tmpl
	for /f "usebackq tokens=1" %%a in (`%%g --config version`) do set gv=%%a
	for /F "delims=." %%i in ("!gv!") do set v=%%i
	sed -e 's/@package@/%PACKAGENAME%/g' -e 's/@version@/%VERSION%/g' -e 's/@grasspath@/%%g/g' -e 's/@grassversion@/!gv!/g' -e 's/^call py3_env.bat/call gdal-dev-py3-env.bat/' qgis-grass.bat.tmpl >%OSGEO4W_ROOT%\bin\%PACKAGENAME%-g!v!.bat.tmpl
	set batches=!batches! bin/%PACKAGENAME%-g!v!.bat.tmpl
sed -e 's/@package@/%PACKAGENAME%/g' -e 's/@version@/%VERSION%/g' python.bat.tmpl >%OSGEO4W_ROOT%\bin\python-%PACKAGENAME%.bat.tmpl
if errorlevel 1 (echo creation of python wrapper template failed & goto error)
sed -e 's/@package@/%PACKAGENAME%/g' -e 's/@version@/%VERSION%/g' process.bat.tmpl >%OSGEO4W_ROOT%\bin\qgis_process-%PACKAGENAME%.bat.tmpl
if errorlevel 1 (echo creation of qgis process wrapper template failed & goto error)
touch exclude
move %PKGDIR%\bin\qgis.exe %OSGEO4W_ROOT%\bin\%PACKAGENAME%-bin.exe
if errorlevel 1 (echo move of desktop executable failed & goto error)
copy qgis.vars %OSGEO4W_ROOT%\bin\%PACKAGENAME%-bin.vars
if errorlevel 1 (echo copy of desktop executable vars failed & goto error)
if not exist %PKGDIR%\qtplugins\sqldrivers mkdir %PKGDIR%\qtplugins\sqldrivers
move %OSGEO4W_ROOT%\apps\qt5\plugins\sqldrivers\qsqlocispatial.dll %PKGDIR%\qtplugins\sqldrivers
if errorlevel 1 (echo move of oci sqldriver failed & goto error)
move %OSGEO4W_ROOT%\apps\qt5\plugins\sqldrivers\qsqlspatialite.dll %PKGDIR%\qtplugins\sqldrivers
if errorlevel 1 (echo move of spatialite sqldriver failed & goto error)
if not exist %PKGDIR%\qtplugins\designer mkdir %PKGDIR%\qtplugins\designer
move %OSGEO4W_ROOT%\apps\qt5\plugins\designer\qgis_customwidgets.dll %PKGDIR%\qtplugins\designer
if errorlevel 1 (echo move of customwidgets failed & goto error)
if not exist %PKGDIR%\python\PyQt5\uic\widget-plugins mkdir %PKGDIR%\python\PyQt5\uic\widget-plugins
move %PYTHONHOME%\Lib\site-packages\PyQt5\uic\widget-plugins\qgis_customwidgets.py %PKGDIR%\python\PyQt5\uic\widget-plugins
if errorlevel 1 (echo move of customwidgets binding failed & goto error)
for %%i in (dbghelp.dll symsrv.dll) do (
	copy "%DBGHLP_PATH%\%%i" %OSGEO4W_ROOT%\apps\%PACKAGENAME%
	if errorlevel 1 (echo %%i not found & goto error)
if not exist %ARCH%\release\qgis\%PACKAGENAME% mkdir %ARCH%\release\qgis\%PACKAGENAME%
%TAR% -C %OSGEO4W_ROOT% -cjf %ARCH%/release/qgis/%PACKAGENAME%/%PACKAGENAME%-%VERSION%-%PACKAGE%.tar.bz2 ^
	--exclude-from exclude ^
	--exclude "*.pyc" ^
	bin/%PACKAGENAME%-bin.exe ^
	bin/%PACKAGENAME%-bin.vars ^
	%batches% ^
	bin/%PACKAGENAME%-designer.bat.tmpl ^
	bin/python-%PACKAGENAME%.bat.tmpl ^
	bin/qgis_process-%PACKAGENAME%.bat.tmpl ^
	etc/postinstall/%PACKAGENAME%.bat ^
	etc/preremove/%PACKAGENAME%.bat
if errorlevel 1 (echo tar failed & goto error)
if not exist %ARCH%\release\qgis\%PACKAGENAME%-pdb mkdir %ARCH%\release\qgis\%PACKAGENAME%-pdb
%TAR% -C %BUILDDIR% -cjf %ARCH%/release/qgis/%PACKAGENAME%-pdb/%PACKAGENAME%-pdb-%VERSION%-%PACKAGE%.tar.bz2 ^
	apps/%PACKAGENAME%/pdb
goto end
:usage
echo usage: %0 version package packagename arch [sha [site]]
echo sample: %0 2.11.0 38 qgis-dev x86_64 339dbf1 qgis.org
exit /b 1
:error
echo BUILD ERROR %ERRORLEVEL%: %DATE% %TIME%
if exist %PACKAGENAME%-%VERSION%-%PACKAGE%.tar.bz2 del %PACKAGENAME%-%VERSION%-%PACKAGE%.tar.bz2
exit /b 1
:end
echo FINISHED: %DATE% %TIME%
endlocal
@echo off
REM    configonly.cmd
REM *        *
REM *        *
set ARCH=%1
	set CMAKEGEN=-G "Visual Studio 16 2019" -A Win32
) else (
	set CMAKEGEN=-G "Visual Studio 16 2019" -A x64
	set ARCH=x86_64
set CONFIGONLY=1
for /f "tokens=*" %%L in (..\..\CMakeLists.txt) do (
        set L=%%L
        set V=!L:SET(CPACK_PACKAGE_VERSION_=!
        if not !V!==!L! (
                set V=!V:"=!
                set V=!V:^)=!
                set _major=!V:MAJOR =!
                set _minor=!V:MINOR =!
                set _patch=!V:PATCH =!
                if not !_major!==!V! set MAJOR=!_major!
                if not !_minor!==!V! set MINOR=!_minor!
                if not !_patch!==!V! set PATCH=!_patch!
package-nightly.cmd %MAJOR%.%MINOR%.%PATCH% 99 qgis-test %ARCH%
endlocal
More information about the QGIS-Developer mailing list
