[QGIS-Developer] sip build err on Debian Testing?
Sebastiaan Couwenberg
sebastic at xs4all.nl
Fri Nov 5 05:29:24 PDT 2021
On 11/5/21 13:13, Richard Duivenvoorde wrote:
> Anybody else seeing this?
Yes.
> Any hints?
pyqt5 was recently updated to use sip6:
https://tracker.debian.org/news/1272065/accepted-pyqt5-5156dfsg-1-source-into-unstable/
Adding the sip6 changes from #45128 & #45829 and updating the packaging
for sip6 helps with this issue, but the build still fails:
Querying qmake about your Qt installation...
These bindings will be built: analysis.
Generating the analysis bindings...
sip-build: Unable to find file "QtCore/QtCoremod.sip"
These bindings will be built: 3d.
Generating the 3d bindings...
sip-build: Unable to find file "QtXml/QtXmlmod.sip"
These files are provided by pyqt5-dev under
/usr/lib/python3/dist-packages/PyQt5/bindings/ but not found for some
reason.
Kind Regards,
Bas
GPG Key ID: 4096R/6750F10AE88D4AF1
Fingerprint: 8182 DE41 7056 408D 6146 50D1 6750 F10A E88D 4AF1
