[QGIS-Developer] Fwd: [Qgis-user] Editing a multipolygon object changes type from Multipolygon to Polygon
Jörg Höttges hoettges at fh-aachen.de
Fri Apr 1 08:38:05 PDT 2022
Hi everyone,
I'm using QGIS 3.16 to 3.22. I created a table with multipolygon objects in a SpatiaLite database. When editing one of
the polygons there appears a warning "Die Operation würden Geometrietyp ändern" ("The operation would change geometry
type") and saving of the changings failes.
Following are the objects before and after the modification:
before editing:
wkt_geom: MultiPolygon (((379698.83699999999953434 5709466.37000000011175871, 379705.34999999997671694
5709460.93499999959021807, 379703.7970000000204891 5709459.07600000035017729, 379697.34799999999813735
5709464.77400000020861626, 379698.83699999999953434 5709466.37000000011175871)))
after adding the point (379701.02700000000186265 5709464.54299999959766865):
wkt_geom: Polygon ((379701.02700000000186265 5709464.54299999959766865, 379705.34999999997671694
5709464.77400000020861626, 379698.83699999999953434 5709466.37000000011175871, 379701.02700000000186265
5709464.54299999959766865))
how can I make sure that the type does not change due to editing? The only idea i have is to remove or modify the
geometry constraint in the Spatialite database table for the geometry column. The warning still appears but saving is
successful.
Interesting fact: The problem didn't appear with QGIS 3.16.
Many thanks for your help!
Jörg Höttges
FH Aachen
University of Applied Sciences
Bayernallee 9
52066 Aachen | Germany
www.fh-aachen.de/menschen/hoettges
URL: <http://lists.osgeo.org/pipermail/qgis-developer/attachments/20220401/18ad3e13/attachment.html>
Type: application/pkcs7-signature
Desc: S/MIME Cryptographic Signature
URL: <http://lists.osgeo.org/pipermail/qgis-developer/attachments/20220401/18ad3e13/attachment.bin>
More information about the QGIS-Developer mailing list
