[QGIS-Developer] Fwd: [Qgis-user] Editing a multipolygon object changes type from Multipolygon to Polygon
Bo Victor Thomsen
bo.victor.thomsen at gmail.com
Sat Apr 2 07:49:45 PDT 2022
I'll just add that I have observed the same behaviour using a
GeoPackage based layer. It was during a teaching session with 10-15
students, so I can't remember exactly how and which editing tool that
was the cause of the error.
Windows 10 / QGIS 3.22.3
Med venlig hilsen / Kind regards
Bo Victor Thomsen
Den 01-04-2022 kl. 17:38 skrev Jörg Höttges via QGIS-Developer:
> Hi everyone,
> I'm using QGIS 3.16 to 3.22. I created a table with multipolygon
> objects in a SpatiaLite database. When editing one of the polygons
> there appears a warning "Die Operation würden Geometrietyp ändern"
> ("The operation would change geometry type") and saving of the
> changings failes.
> Following are the objects before and after the modification:
> before editing:
> wkt_geom: MultiPolygon (((379698.83699999999953434
> 5709466.37000000011175871, 379705.34999999997671694
> 5709460.93499999959021807, 379703.7970000000204891
> 5709459.07600000035017729, 379697.34799999999813735
> 5709464.77400000020861626, 379698.83699999999953434
> 5709466.37000000011175871)))
> after adding the point (379701.02700000000186265
> 5709464.54299999959766865):
> wkt_geom: Polygon ((379701.02700000000186265
> 5709464.54299999959766865, 379705.34999999997671694
> 5709466.37000000011175871, 379701.02700000000186265
> 5709464.54299999959766865))
> how can I make sure that the type does not change due to editing? The
> only idea i have is to remove or modify the geometry constraint in the
> Spatialite database table for the geometry column. The warning still
> appears but saving is successful.
> Interesting fact: The problem didn't appear with QGIS 3.16.
> Many thanks for your help!
> Jörg Höttges
> FH Aachen
> University of Applied Sciences
> Bayernallee 9
> 52066 Aachen | Germany
> www.fh-aachen.de/menschen/hoettges
> QGIS-Developer mailing list
> QGIS-Developer at lists.osgeo.org
> List info:https://lists.osgeo.org/mailman/listinfo/qgis-developer
> Unsubscribe:https://lists.osgeo.org/mailman/listinfo/qgis-developer
URL: <http://lists.osgeo.org/pipermail/qgis-developer/attachments/20220402/064a8794/attachment.html>
