[QGIS-Developer] Problems with MAC and OneDrive
Carlo A. Bertelli (Charta s.r.l.)
carlo.bertelli at gmail.com
Mon Apr 4 15:34:28 PDT 2022
> Is there versioning control built into OneDrive?
Yes, as you can see here:
https://support.microsoft.com/en-us/office/restore-a-previous-version-of-a-file-stored-in-onedrive-159cad6d-d76e-4981-88ef-de6e96c93893
you can restore a previous version of a file stored in OneDrive. To what
means, I don't know, but sharing a SQLite, Spatialite or GPKG on cloud
storage is really a stress test for the concept of file sharing,
especially if it's shared (and if you are the same user on two platforms,
you have to be very very lucky.
On Tue, Apr 5, 2022 at 12:07 AM Patrick Dunford via QGIS-Developer <
qgis-developer at lists.osgeo.org> wrote:
> I'll endorse that plus in noting that I have seen tables wiped clean
> with geopackage where there may be multiple users. Even if there is only
> one actual user, there is a risk with multiple clients on a file based
> system because there is no inherent mechanism with the file based layers
> to handle transactions the way there would be with a DBMS server. SQLite
> is not recommend over a network for multiple clients.
> That is separate from the other point which is that any one local client
> can overwrite the cloud version which is risky. Is there versioning
> On 5/04/22 03:33, Carlo A. Bertelli (Charta s.r.l.) via QGIS-Developer
> wrote:
> > Could you please provide some more info about the format of the data?
> > I think your question does not imply using a DBMS server which I could
> > suggest in this case. Sharing a file that can be updated on a remote
> > file system involves some (risky) reaction, but cloud storage is
> > different, it involves syncronisation and I think it requires some
> > planning and careful evaluation of the consequences of the choices of
> > every participant in the workgroup. If you synchronise the empty file
> > towards a non-empty version... you get an empty file.
> > Maybe you can recover the work looking to all the revisions of the
> > same file on Onedrive. Good luck.
> > c
> QGIS-Developer mailing list
> QGIS-Developer at lists.osgeo.org
> List info: https://lists.osgeo.org/mailman/listinfo/qgis-developer
> Unsubscribe: https://lists.osgeo.org/mailman/listinfo/qgis-developer
URL: <http://lists.osgeo.org/pipermail/qgis-developer/attachments/20220405/5cc28329/attachment.html>
